2015 Mustang GT Profile
2015 Mustang
GT  (boardkat's Optima/TT/AutoX Build)
S550 Model
GT
Steeda Road Race Front K-Member
JRZ RS Pro Double Adjustable Remote Reservoir Offset Struts/Inverted Shocks w/ Spherical Mounts/Eyelets
JRZ Camber Plates
Hyperco 2.25ID 5" 750lbs Front Springs
Bimmerworld Spring Thrust Sheets
Steeda 38mm FSB w/ Delrin Bushings
Steeda Aluminum FSB Mounts w/ Zerk Fittings
Cortex Racing Adjustable Front Spherical Endlinks
Cortex Racing Front Control Arm Spherical Bearings
Steeda Bumpsteer Kit
Steeda Front Control Arm Lateral Links w/ Extended Ball Joint
MMI Adjustable Articulating Rear Perches
Hyperco 2.25ID 6" 1300lbs Rear Springs
GT PP 22.2mm RSB w/ Poly Bushings
Cortex Racing Adjustable Rear Spherical Endlinks
Cortex Racing Rear Control Arm Spherical Bearings
Steeda Poly Vertical Links
BMR Spherical Toe Links
Ford Racing Toe/Knuckle Spherical Bearings
Steeda Spherical/Delrin Adjustable Rear Camber Links
BMR Delrin Rear Subframe Bushings
BMR Poly Differential Mount Bushings
Forgestar CF5 18x12" Front/Rear Wheels (dry/warm/track/autox)
Yokohama ADVAN A052 315/30R18 Front/Rear tires (dry/warm/autox)
Forgestar F14 18x13" Front/Rear Wheels (dry/warm/autox)
BFGoodrich g-Force Rival S 1.5 335/30R18 Front/Rear Tires (dry/warm/autox)
Forgestar F14 19x12" Front/Rear Wheels (track testing)
Goodyear Eagle F1 Supercar 3 325/30R19 Front/Rear Tires (dry/cool/track)
SVE 350R 19x11" Front/Rear Wheels (wet)
Michelin Pilot Sport 4S 305/30R19 Front/Rear Tires (wet)
Optimum Performance Front Aluminum Wheel Spacers
Optimum Performance GT4 Front Wheel Studs
ARP Extended Rear Wheel Studs
Optimum Performance High Strength Racing Lug Nuts
AP Racing 6pot Front Calipers
AP Racing 372x34mm 2pc Slotted Front Rotors
Carbotech XP20 (track) / XP8 (autox) Front Brake Pads
Optimum Performance Titanium Front Brake Pad Shims
Steeda Stainless Front Brake Lines
Custom 3D Printed Front Brake Duct Inlets w/ 2.5" Ducting
AP Racing 4pot Rear Calipers
AP Racing 340x28mm 2pc Slotted Rear Rotors
Carbotech XP10 (track) / AX6 (autox) Rear Brake Pads
Steeda Stainless Rear Brake Lines
JBA Balanced & Blueprinted Coyote Performance Engine (9.35:1)
- 0.010 Overbore
- Deck Plate Honed Cylinders
- Main Housing Bores Align Honed
- Block Deburred and Radiused
- Rotating Assembly Balanced
- Oil System Modifications for High RPM Flow
- Rod Clearances Set
- Rings Hand Gapped and Filed
- Manley 598110CE-8 Forged and Coated Pistons
- Manley Stainless Steel Ringset
- Manley 9310 Alloy Wristpin
- Manley Forged H-Beam Connecting Rods
- Tri-Metal Performance Main Bearings
- Tri-Metal Performance Coated Rod Bearings
- ARP Head Studs and Rod Bolts
- Manley Valve Springs
- Ford Performance Billet Oil Pump/Gears
- MMR Billet Crankshaft Gear
- Ford Racing Boss 302 Timing Chain Tensioners
- Livernois Billet Pivoting Timing Chain Guides
- ATI Harmonic Balancer
- Ford Performance GT500 Aluminum Valve Covers
- Ford Performance FP350S Oil Pan
VMP Gen 3 TVS 2650 Supercharger
Department of Boost GT550 Manifold
VMP 67mm Dual Blade Throttle Body
Fore Innovations L4 Fuel System
- Fuel Rails in Parallel w/ Regulator Mounted After
- TI Auto F90000274 Primary Pump
- TI Auto F90000274 Secondary Pump
- F2i 2 Port Regulator
- FC3 Staged Controller w/ 4ga wiring
- FC3 Honeywell Pressure Switch
- PTFE -8 Feed / Return lines
- 128mm Microglass SSD Filter
- 0-100 psi Fuel Pressure Gauge
Radium Engineering Fuel Pump Hanger
ID1050x Injectors
NGK Iridium IX Spark Plugs
JLT 125mm Cold Air Intake
Velossa Tech Big Mouth Ram Air
Tracy Lewis Performance Signature Series Monster Dual Valve Catch Can
Fathouse Fabrications Valve Cover Fittings
BMR Poly Motor Mounts
Livernois EvenFlo 170 Degree Thermostat
Stainless Works 1 7/8" Headers
Stainless Works Hi-Flow Metal Matrix 200 Cell Cats
Borla Touring 2.5" Catback Exhaust
Ben Calimer MT82 Stage 3 Transmission w/ GForce Engineering Gearset
Ford Performance Ti-VCT High RPM Competition Pulse Ring
McLeod RXT 1200 Clutch
McLeod Lightened Steel Flywheel
Ford GT500 Slave Cylinder and Throwout Bearing
MGW Race Spec Short Throw Shifter
Steeda Clutch Spring/Perch
QA1 REV™ Series SFI 43.1 Approved 1pc Carbon Fiber Driveshaft
OS Giken Super Lock 1.5 Way LSD
Ford Performance 3.55 Ring and Pinion
Fluidyne Triple Pass Radiator
Department of Boost Titanic Triple 1000cu in -20AN Heat Exchanger
Stewart E2512A 25amp Water Pump
Roush Heat Exchanger Coolant Tank
Canton Racing Oil Filter Adapter
Improved Racing Remote Oil Filter Mount/Thermostat
Setrab 650 -10AN Engine Oil Cooler
Setrab 610 -08AN Transmission Oil Cooler
Tilton Engineering Transmission Oil Cooler Pump
Custom Aluminum Radiator Fencing
Full Tilt Boogie Racing Differential Cooler/Fan
Anderson Composites Dry Carbon Fiber Doors
Watson Racing Front Bumper Support
Watson Racing Rear Bumper Support
Planted Seat Brackets w/ Aluminum Side Mounts
Ford Performance GT350R Rear Seat Delete
Ford Aluminum Differential Carriage
Watson Racing Battery Relocation Kit
Ford Performance A/C Compressor Delete Pulley
PBH Performance A/C Compressor Delete Bracket
Fog Light Delete
Strut Tower Brace Delete
Cowl C-Brace Delete
Watson Racing 6pt Rollbar
Safecraft 5010 6pt Harnesses
Sparco Ergo II Driver Seat
Sparco Evo II LF Passenger Seat
Ford Performance Front Tow Hook
Ford Performance Rear Tow Hook
AeroCatch Xtreme Plus Flush Hood Latches
Amsoil Signature Series 5W-50 Engine Oil
Amsoil 75W-90 Manual Transmission & Transaxle Fluid
OS Giken OS-250R 80W-250 Differential Fluid
Castrol SRF Brake Fluid
AiM Solo 2 DL (track) / Petrel Data Systems SoloStorm (autox)
GlowShift Diff/Tranny/Engine Oil Temp Sensors/Gauges
Anderson Composites Type-TW Carbon Fiber Vented Hood
Anderson Composites Type-GT Carbon Fiber Front Upper Grille
Anderson Composites Type-GT Carbon Fiber Front Lower Grille
Anderson Composites Type-GR Carbon Fiber Side Rocker Panel Splitters
Carbon Composites GT350R Rear Wing
AJ Hartman Aero Front Splitter
AJ Hartman Aero Canards
Verus Engineering Rear Diffuser
boardkat
More in S550 Mustangs
