2005 Mustang GT_46L Profile
2005 Mustang
GT_46L  (Fiona - Road Course, AutoX, and Optima Build)
S197 Model
GT 4.6L
H&R Sport Performance coilovers and dampers
Eibach sway bars - front adjustable
MM caster/camber plates
MM bumpsteer kit
MM adjustable rear control arms
BMR adjustable rear upper control arm
JLT rear diff catch can
F - Brembo 14" 4P, KNS by DBA rotors, Carbotech XP-20 race pads, and Boss 302 brake ducts
R - Stock calipers, KNS by DBA rotors, and Carbotech XP-12 race pads
Apex Racing SM-10 wheels or HRE FF15 wheels - both in 19x10 ET40
Steeda radiator support
FRPP 3.720 bore iron alloy block (BOSS50) 519whp - 501 ft lb on low boost
Livernois 3V stroker crank by Kellogg (3.75" stroke)
Livernois H beam stroker rods (by Manley)
Diamond 3.720 stroker pistons w/ 22cc dish (9.5:1 compression) w/ Total Seal stainless steel rings
JDM Engineering cams w/ custom grind
FoMoSport Stage 3 heads w/ over sized valves (50cc combustion chamber) w/ FRPP etched valve covers
Cometic head gaskets
Phase locks
ARP head studs
Kenne Belle Stage 2 - 2.6L supercharger
8-rib overdrive serpentine belt system with DOB Frankentensioner
FRPP dual 62mm throttle body
JBA long tube headers 1 5/8" primaries w/ 3" collectors, gutted JBA shorty H-pipe, Roush Extreme Performance pipes, MBRP SS mufflers
Fore Innovations dual pump (TI 90000274 primary and TI 90000285 secondary) w/ 8AN lines
Advanced Fuel Dynamics Pro Commander adaptive flex fuel system
BBK high flow aluminum fuel rail kit w/ ID1000 injectors flowing E85 or 93 octane pump gas
Meziere electric water pump
Mishomoto high capacity performance radiator
Mishomoto oil cooler kit w/ thermostatic sandwich plate
Livernois billet oil pump gear-rotor in FRPP hi pressure oil pump
2013 GT500 8-quart cast aluminum oil pan
Pro-Dyno tune by Dan Desio
Black paint above the style line and rear decklid - Silver painted pinstriping
Kaenen 3" cowl hood
Foglight delete and black billet grill
Roush fuel door
Roush side skirts
Ford Racing by AutoMeter gauges (water temp, oil temp, fuel pressure)
MM 6-point roll bar w/ removable harness bar and door bars
Schroth 6-point harnesses
OMP HTE-R XL seats - driver and passenger
Rear seat delete
Pump and fan switch panel
I purchased Fiona from a West Point automotive engineer that had done several mods to the car. Some done well, some not so much. If something breaks, I improve it.
Boone
More in S197 Mustangs
