- 6,452
- 8,378
I'm sorry, I should've explained, it's used to Purge a tire of air.And for the uneducated amongst us? Assuming by the looks its a clip on bleeder that allows you to drop the tyre down to atmospheric pressure without pulling the valve insert. Assume you then attach compressor hose and refill via the fitting on the end. Never really thought about changing out the air in tyres given they get refilled from a multitude of dubious sources. Sounds so obvious when you sit and think about it. I'll add it to the list of driver excuses for poor performance on the day.
Do you pull a slight vacuum if possible to try remove as much "moist" air as possible?
What else am i missing from a seemingly simple device that obviously has a genuine purpose given @blacksheep-1 is telling us about it. It must be useful.
With the valve core removed won’t the tire just fill up with air when the hose is removed?I'm sorry, I should've explained, it's used to Purge a tire of air.
When you get the tires mounted they are done with air. To remove that and ( most) moisture you use this tool.The valve core is removed, the tire bled, then the hose with the clip is attached to the valve stem. Compressed air is run through the black aluminum piece and it acts as a very efficient siphon, pulling a vacuum on the tire. Shut the valve off, remove the hose, reinstall the valve core and you are ready for nitrogen. These things work like a champ and were out of production for quite awhile.
You can actually pull a tire off the bead with one of these.
If you let it sit long enough. You can literally suck the tire down and off the wheel bead. You have be careful using one of these under about 35 degrees because you can damage the tire and break the cords as it wrinkles up.With the valve core removed won’t the tire just fill up with air when the hose is removed?
So i was correct, way more to it than i imagined.I'm sorry, I should've explained, it's used to Purge a tire of air.
So we have to call him Don Blackseep now?That's the reason you are the head of the Mafia, THE TYRE GUY MAFIA.
