Tire Purging Tool finally back in stock
80
143
Melbourne Australia
And for the uneducated amongst us? Assuming by the looks its a clip on bleeder that allows you to drop the tyre down to atmospheric pressure without pulling the valve insert. Assume you then attach compressor hose and refill via the fitting on the end. Never really thought about changing out the air in tyres given they get refilled from a multitude of dubious sources. Sounds so obvious when you sit and think about it. I'll add it to the list of driver excuses for poor performance on the day.
Do you pull a slight vacuum if possible to try remove as much "moist" air as possible?
What else am i missing from a seemingly simple device that obviously has a genuine purpose given @blacksheep-1 is telling us about it. It must be useful.
73
113
West
One might use this to evacuate the air in a tire before refilling with nitrogen I think. Might also refill with helium to reduce unsprung weight?
6,444
8,367
I'm sorry, I should've explained, it's used to Purge a tire of air.
When you get the tires mounted they are done with air. To remove that and ( most) moisture you use this tool.The valve core is removed, the tire bled, then the hose with the clip is attached to the valve stem. Compressed air is run through the black aluminum piece and it acts as a very efficient siphon, pulling a vacuum on the tire. Shut the valve off, remove the hose, reinstall the valve core and you are ready for nitrogen. These things work like a champ and were out of production for quite awhile.
You can actually pull a tire off the bead with one of these.
1,190
1,199
Lenoir City TN
With the valve core removed won’t the tire just fill up with air when the hose is removed?
6,444
8,367
If you let it sit long enough. You can literally suck the tire down and off the wheel bead. You have be careful using one of these under about 35 degrees because you can damage the tire and break the cords as it wrinkles up.
143
Melbourne Australia
So i was correct, way more to it than i imagined.
That's the reason you are the head of the Mafia, THE TYRE GUY MAFIA.
Thanks for the insight, another item to add to the list of purchases.
