This is the Build Thread for 2005 ST3 Build. Reply below.
Yup. Needs a lot of work to get back on track, but the cage and body are nice.I think I saw this thing on facebook marketplace. It's a roller right?
Looks like a really nice setup
Hardline looks ok, bracket should be an L-shape that stands out and back.Can anyone help me out with brake line routing? Not sure where the flex hoses are supposed to attach to the strut or the body. The stoptech kit came with these brackets and some clamps. Is my hard line that messed up?
That looks really good. Today I was trying to get brake ducting installed but using the Boss LS approach with the fog lamp bezel then add hardware store plumbing pieces. Mine is so bad I couldn’t look at it any longerPut the 3D printer to good use and made some brake duct inlets. Needs revision, but not bad for a first draft.
View attachment 86073View attachment 86072
I've been there; the first ducts I made for my 2015 were half PVC. If I'm happy with how these turn out I can make you a set. I'm printing a revision now, if it fits I'll work on mounting tabs and post an update.That looks really good. Today I was trying to get brake ducting installed but using the Boss LS approach with the fog lamp bezel then add hardware store plumbing pieces. Mine is so bad I couldn’t look at it any longer
That would be great. I saw this car when is was up for sale and it was tempting but it was beyond my ability to finish it, good luck to you. The pic of your 3D duct looks like it’s in a 13/14 bumper cover. Is that what is on your 2005 car? I am working with on a ‘14. I can send and dims for the tabs if you need it. Regarding the fog light bezel, the cover tabs and bezel tunnels (for fog light mounting screws) are weird as they are not in a the same plane making off/on significant interference, unless I just didn’t understand it after way too long trying to separate bezel from cover.I've been there; the first ducts I made for my 2015 were half PVC. If I'm happy with how these turn out I can make you a set. I'm printing a revision now, if it fits I'll work on mounting tabs and post an update.
Yes, my car has a 2013 front end on it. I don't have a factory fog light bezel, but I printed a version that mates up to the factory tabs and mounting points. I'm printing another (hopefully the final) version now with a couple of minor adjustments and in a more durable material.That would be great. I saw this car when is was up for sale and it was tempting but it was beyond my ability to finish it, good luck to you. The pic of your 3D duct looks like it’s in a 13/14 bumper cover. Is that what is on your 2005 car? I am working with on a ‘14. I can send and dims for the tabs if you need it. Regarding the fog light bezel, the cover tabs and bezel tunnels (for fog light mounting screws) are weird as they are not in a the same plane making off/on significant interference, unless I just didn’t understand it after way too long trying to separate bezel from cover.
Forgive the intrusion. I was searching the forums this morning for this with no luck, then remembered seeing your build earlier in the week. Love the look of your car. I drive a 2009 GT. Is the 2013 bumper cover a straight swap? Or must you also swap the hood and/or fenders? Thanks!Yes, my car has a 2013 front end on it. I don't have a factory fog light bezel, but I printed a version that mates up to the factory tabs and mounting points. I'm printing another (hopefully the final) version now with a couple of minor adjustments and in a more durable material.
Thanks. I believe you need to swap the entire front end, hood and fenders included. This was done to my car before I purchased it. I will say the fenders and doors don’t line up well, but for race car purposes it looks fine.Forgive the intrusion. I was searching the forums this morning for this with no luck, then remembered seeing your build earlier in the week. Love the look of your car. I drive a 2009 GT. Is the 2013 bumper cover a straight swap? Or must you also swap the hood and/or fenders? Thanks!
