2011 V6 6-Speed Mustang for Endurance Racing
Do you have the rulebook for the race series you want to participate in? Would be an interesting read. I wonder if since it's a Ford part that came in OEM vehicles if there's a loophole on what 'stock' is :)
Yep, that's the issue. The rules say we can use the diff if it was available for the year/make/model or generation of the car, but it excludes the Boss/GT500/etc since it's a specialty/high-performance model.
The gear rules are a similar story. We can use any factory-offered ratio for our year/make/model or generation, excluding specialty models like Boss 302. We had an idea last night that would possibly allow us to use 3.73s...we think those were offered in the 05-09 Mustang GT, which would make them allowed for our car (same generation). But we think they're too low for the job anyway.
2011 GT was offered standard with 3.31s, but 3.55s or 3.73s were a factory option on manual transmission Mustangs.
Another thing to keep in mind is that the 2013-2014 Mustang GT had the Track Pack option, which from factory included the Boss 302 Torsen. If you're allowed 'regular non-special version' parts from your generation, that covers a helical type differential since the GT is neither a Boss, Shelby, etc.
So I wouldn't see the problem based on your explanation of the rules in running any GT rear gear (3.31, 3.55, or 3.73) with the Boss Torsen you said you already have. You may even be able to use the automatic's 3.15 rear gear ratio if it worked better with your V6 transmission for the specific track you were looking to run at.
This is where the rules get confusing. I don't think we can use parts from cars that are not on the allowed list. But the rule doesn't really say that.
Here's the full Champ rule so that I'm not just giving you half of it or my (possibly flawed) interpretation:
"Differential swap: 25pts for any diff not originally available for your year, make, and model or chassis generation (excluding specialty high performance models not listed on the VPI table). Includes axles and CV’s."
"Final drive ratio is open to all factory offered ratios for that body style or chassis generation. If that body style or chassis generation was offered from the factory with an LSD, its use is permitted. Specialty high performance models not listed on the VPI table are excluded."
2011-14 Mustang GTs are not on the approved list. So I was thinking the only "factory option" parts we could run are:
-2005-09 Base or GT
-2011-2014 Base
From what we found last night, the 05-09 GT had a 3.73 option. So it's possible to run that; it's the same generation and on the allowed list. But the Torsen...I'm thinking it's a no-go, since that "Track Package" might be a specialty high-performance model and not on the VPI list.
Here's where the nuance could potentially come in. The Mustang GT is a model (could be further refined by saying that GT is a trim of the Mustang model, but that would open up the Boss 302 as being a trim as well). The Track Package is an option on that model/chassis and is included as a factory part on your chassis generation. I don't think anyone would call a GT a 'specialty' model, unless you're saying that a Mustang GT couldn't run in the same series you are? Is there a sanctioning body you can reach out to for clarification on the verbiage?
The Brembo Brake Package was the track-package-by-another-name in 2011 and 2012. It had the upgraded 14" 4-piston brakes (which the Boss-to-be later used in 2012) and a retuned suspension with different springs and dampers. They added additional parts-bin features in the 2013-2014 Track Package as carryovers from the Boss. I personally think based on the limited information I've seen so far that it would allow you to run all of those components that were not exclusively offered in the Boss 302, including better 4-piston calipers and the helical diff.
8,496
8,497
Trying to out think the rules usually ends up with one getting protested since there is almost always a statement noting that if an option is not specifically included, adding it something you don't find specifically excluded is ok. Rule of thumb is if looking for gray areas, they have been viewed by many so often the " Rules Committee " often just comes down to whether an item on a approved list --- not on the list, you are better off skipping any rationalizations on why you can use your secretly found mod.
Yes, that's the case here. Except 05-09 GTs can run with us, 2010+ GTs can't (yet anyway).
That is also correct. They do have that in there.
NorCal
Not sure if this helps, but for 'stock' I've seen GT referenced here a bit, but no mention yet of V6 Performance Pack that was a 2012 factory option, if this helps you at all:
V-6 Perf. Pack comes with:
Shelby GT500 rear lower control arms
Mustang GT front struts and rear shocks and springs
Mustang GT coupe front and rear stabilizer bars
Mustang GT front and rear calipers w/ Performance Friction pads
Front strut tower brace
3.31:1 rear end ratio
19" wheels with Pirelli P-Zero 255/40-19 summer tires
Two-stage electronic stability control with a unique sport mode
I'm interested in what you come up with for one piece driveshaft for the V6 / Manual.
We did find and buy the aluminum 1-piece driveshaft. Not a cheap upgrade, but we thought it was mandatory for safety. Lethal Performance is where we got ours, I think...maybe a Dynotech brand?
We did use some of the V6 PP stuff...Shelby rear control arms, 3.31:1 gears, and front strut tower brace. We have not swapped sway bars or played with them yet...car handles very good as is right now, and we haven't gone to any HPDE days to do proper testing. That should change in June with the Mid-America Ford and Shelby meet at Hallett. I plan to bring some GT sway bars and test a few combinations.
Brakes are open, so we run Boss 302 Brembos in front with GLOC R18 pads. Vorshlag backing plates and 3" ducts off the lower grill. Rears are GT500 rotors and GLOC R10s. No complaints in the braking department...
We went to Daytona again this past weekend. Car ran a respectable 2:14.x on the road course once we had some clearer laps (i.e. the sketchy drivers had wrecked...so half the field was gone). Fastest cars were in the 2:10-2:12 range. I was running 2:21s pretty consistently in an early stint. We had 4 more drivers after me and I needed to really take care of the car, so that was granny shifting and staying well away from the sketchy drivers, which forced me to take some unique lines. Some of those guys just don't give a crap. Oh and AdvanceTrac wouldn't turn off before I got out there, so I was fighting the engine cuts and goofy braking trying to spin the car if I drove too hard. No sport mode in our car. We think we found a way to shut it off entirely with Forscan, so fingers crossed that works out.
