2012 Boss 302 Photo Thread
Knappj69,
It is a hard choice sometimes, but today, at 94 degrees outside, the Mach 1 a/c does not work, so I drive the Boss!
However, somewhere along the line, someone removed the a/c compressor, so I will have it replaced, then my Mach 1 will be complete.
Jeff
Jeff Quinn said:
Knappj69,
Jeff
No a/c would make the choice easier this time of year. They are both sharp cars.
Justin
Me finishing up the first Zaino treatment
Local car show:
I sent my fuse box cover off to get overlayed with the same cf weave pattern as my rad cover:
Carbon fiber underhood dress-up. In this pic you can see the blue painters tape holding the windshield squirters out of the way...I need to remove the whole setup including washer bottle:
BlackNDecker said:
Local car show:
Looks good! ;)
ace72ace
1,242
71
Love the Kona, would have been my first choice for a '12. What do you use for wax/polish?
8,733
2,735
reakhavok said:
Had to take a few things apart to install the hood pins for the 302s hood. think I also installed the brake cooling kit while it was apart.
[ig width=900 height=675]http://a1.sphotos.ak.fbcdn.net/hphotos-ak-ash3/544850_342235495824350_100001137066860_897072_721289975_n.jpg[/img]
Did you have to drill through the bottom of the upper radiator support to be able to tighten the lower nut on the pins? If not, how do you tighten them down? Got a set of sparco pins in the garage waiting or my tiger hood to be installed...
