2016 Ford Performance Parts Catalog
VoodooBoss
Rick
I received a copy of the new 2016 Ford Performance Parts Catalog today and it has a few interesting items in it that S550 owners will like.
GT350 Radiator - M-8005-M8
The GT350 radiator is available and bolts right into the S550. Just like the Boss radiator worked in the S197 cars.
https://fordperformanceracingparts.com/parts/part_details.asp?PartKeyField=24663
The rear valance is available with a number of exhaust options. Here's one.
https://fordperformanceracingparts.com/parts/part_details.asp?PartKeyField=25319
Ford Performance Windshield Banner
The new banner is available.
https://fordperformanceracingparts.com/parts/part_details.asp?PartKeyField=25193
2015+ Trans Scoop M-5025-M8
Similar to the one on the Boss 302
https://fordperformanceracingparts.com/parts/part_details.asp?PartKeyField=25187
2015+ Track Lowering Springs M-5300-Y
Y is the new P. 8)
https://fordperformanceracingparts.com/parts/part_details.asp?PartKeyField=24806
2015+ Deck Lid Trim Panel M-16600-M
In case you want to remove the emblem on the rear of your pony.
https://fordperformanceracingparts.com/parts/part_details.asp?PartKeyField=25064
Thanks to @BigTaco for grabbing me a catalog from SEMA!
Other updates are in the thread below.
https://trackmustangsonline.com/index.php?topic=10399.msg149755#new
TMSBOSS said:
Are these flywheel numbers? Just about have to be?
Has anyone priced either combo?
What computer/software upgrades are required.......Yes, interested!!
Has to be flywheel
Heads are 2500 a piece minus cams, no price yet on cams but expect 800 to 900 a set???
and probably another 500-600 bucks for rockers/lash adjusters
CJ Intake/TB/CAI another 2000
So 9400+/- to swap out the top end (Parts only)
then you need some one to tune it for 500 to 1,000
8)
VoodooBoss
Rick
ilesjohn said:
Has to be flywheel
8)
Yea I think the big numbers are coming from the voodoo heads that breath more. You must be the one talking to Filip about this. ;)
i wonder if the cobra intake/tb will fit the stock voodoo motor.
VooDooBOSS said:
Wow. I thought the voodoo intake was more for torque and possible hood clearance. I'm sure 600 HP from the voodoo motor is within reach with no boost.
Note the 5.2L in the image uses a CPC not a FPC.
VoodooBoss
Rick
Re: 2016 Ford Performance Parts Catalog 5.2L Coyote Eliminator XS
More info on the 5.2L at PRI. @TMSBOSS shoot put my voodoo on a stand and install this bad boy. Makes you wonder just a bit why they went with a FPC in the first place. Regardless nice to see the guys at Ford Performance pushing this platform further.
http://www.stangtv.com/features/pri-coverage/pri-2015-inside-ford-racings-new-5-2-coyote-crate-engine-a52xs/?utm_source=rss&utm_medium=rss&utm_campaign=pri-2015-inside-ford-racings-new-5-2-coyote-crate-engine-a52xs
mattlqx
Mustangless
I'm a layperson when it comes to engine specifics, but does this mean we'll see a bunch of Voodoo owners putting on a Cobra Jet manifold like we saw with Coyotes and Boss manifolds? Will you get another X horsepower on the intake alone or will there need to be other supporting mods for extra oomph?
VoodooBoss
Rick
Possibly but there will be issues fitting it under the GT350 hood.
The CJ intake, while very similar to the Boss intake, improved a few things over the Boss. There are further enhancements to the flow characteristics and the big one is the ability to use a much larger throttle body (that specific info is posted here somewhere). When the Boss intake was under development they wanted to use a larger TB but didn't have an OEM one available. The CJ intake solved that with the ability to use the Ford Racing TB's that were available. Those two TB's appear to flow more than the voodoo TB and hence there should be the potential for more performance considering the better flowing voodoo heads. Due to vibration concerns and keeping your warranty intack I'd let others test that first.
Note that FP is coming out with a voodoo intake kit for the coyote. While the voodoo TB is not as large as the two TB's that fit the CJ intake I suspect the voodoo intake kit, which includes the intake, TB, CAI and tune, will be a better balance between HP and TQ for the coyote. Ford Performance has been testing that kit for over a year and if you look closely at the video below you'll see a split second glimpse of the voodoo intake on the 2015 5.0. ;)
https://www.youtube.com/watch?v=Kulx2AfNZuY
Now that the first sets of aftermarket 'R' wheels have an ETA of February, any chance that FP will have the lower front springs available by then?
VoodooBoss
Rick
GT350R and TP Strut Tower Brace Kit
https://fordperformanceracingparts.com/parts/part_details.asp?PartKeyField=25987
GT350R Steering Wheel
https://fordperformanceracingparts.com/parts/part_details.asp?PartKeyField=25908
GT350R Rear Seat Kit
https://fordperformanceracingparts.com/parts/part_details.asp?PartKeyField=25876
Hood Lift Kit
https://fordperformanceracingparts.com/parts/part_details.asp?PartKeyField=25911
Anyone planning to get the GT350R wheel to match the red shift knob? Was thinking about it, would also keep the original wheel in good shape since the alcantara tends to wear over time
VoodooBoss
Rick
Yes, it will look nice on my RR GT350. I'll sell my stock wheel though. I'm also planning on doing alcantara shift boot and parking brake with red stitching to match. I installed the GT500 alcantara pieces on my Boss and liked the look so I'll do it again.
http://www.redlinegoods.com/Mustang15shiftboot.php
