Hello,
I was curious to know if anyone is replacing the Caliper/Bracket bolts with any frequency while doing run of the mill brake pad and disk swap work? I thought I read somewhere these bolts should be replaced (ie..one time use hardware) but I could be smoking the crack pipe again? :-\
Also, anyone know the OEM Part # for these bolts I am referring to? I cant seem to find them anywhere online.
Next up, it seems that the Brembo branded Caliper "Clip Kit" (7R3Z-2B164-A) has been abandoned by Ford. I've seen a few sites mention that this kit has been Discontinued
.....Is there any reason to believe that the freely available Centric branded equivalent (MPN# 117.46021) is of any lesser quality?
Lastly, anyone know the OEM Part # for the rear caliper banjo "Flow" bolts used to attach the brake lines to the rear calipers? This is another Part that has been a challenge to find Online. I've been trying to avoid going to the stealership for this stuff but I may to give in ???
Thanks for any info you can provide
