AIM brake pressure sensor part number?
Does anyone know the part number for an AIM brake pressure sensor for my 2012 Mustang GT ? And a patch cable, if needed? Finally upgrading to a MX data logger and SmartyCam, and want accurate brake pressure data, which is not provided by the ECU.
Thanks in Advance,
TS
captdistraction
GrumpyRacer
There's a sensor in the ABS module, when you say accurate data, are you not getting anything or you want the raw pressure data? (the data in the ABS PCM is: CAN ID 529, offset 7 - a single byte raw value return that appears to show values from 0-255)
I have mine scaled at .667 as even the most heavy stabs of the brake I could do with engine on only returned a value of ~150
Latest lap times
