S197 3V Auto to manual - hptuners ecu changes
Hi. So my manual transmission conversion I completed a few weeks ago. Car is in limp mode. I should get my hptuners stuff next week. My friends Dyno shop uses hptuners. I have tried to google instructions on what to change in hptuners ( I’m not familiar with it at all - yet ), but I didn’t find steps from anyone. Anyone here done the swap and have some notes/pointers on what to change in the ecu for the swap? I found a article on deleting vats. Car is track only, 2005 gt converted to a tremec. So I wanted to tackle vats and the driveline before I go to the dyno. Will save me a few bucks if I figure it out. Thanks in advance if someone can point me to a thread or provide the steps.
6,410
8,310
All the hot dog tuners seem to graduate to HP. I guess they allow specific engine parameter and the ability to assign component values is their thing. I know Phoenix uses them almost exclusively.
Hi, my tuner cant make the car go after the swap, Im sure he is missing a config tweak. Who is Pheonix? Can you share some contact info as I might need to find some help.
6,410
8,310
Tell them Rob sent you
Kennett Square, PA
Rob asked me to chime in. Your problem is most likely that the electronic throttle monitoring software version in the manual trans strategy you are using doesn't match the automatic PCM you are using. To make a long story short(er) the PCM has a separate processor that is responsible for all of the safety monitoring of the electronic throttle, and the main engine calibration checks the software version in the ETC processor to make sure it matches. If you go to a dealer and have your PCM reprogrammed from one strategy to another (like an automatic to manual) it programs both processors. But if you change your strategy using SCT or HPT it only changes the main processor and there is a chance it won't match, and then you'll get limp mode.
To fix it, you need to look at a calibration for the strategy that was originally in the PCM and find the Equizzer Software Version and IPC Software Version, which should be the same 3 digit number. Then go into your manual transmission calibration and change them both to match.
My tuner responded finally with the codes the car is throwing.
p061c and p2106. I guess thats progress, I can start to do some googling.
And I passed on the info from from the thread above, thanks for that info.
It still has the auto diff for now and he want to change some ratios, but I dont know if he is on the right track. I am going to slap my buddy who said turn the car to a manual, it will be fun he said...Im lucky that the dyno shop guy hasnt given up, he will put car back on dyno between other bookings and continue to work on it.
Manuel at tudyno.com ( highly recommended 3v tuner ), says he can tune a autopcm to work with SCT tuning hardware, I have HP tuners, he doesnt think HP can do it. Its only money at this point.
I have to decide once my tuner gives up.
1) Standalone engine management, expensive and have to wire in, pro is it would work if I upgrade to a 5.0 later which is likely. Brake/suspensions mods are definetly setup for more HP. Just need some seat time int he car before going down that road.
2) Buy a manual PCM and spend more HP tuner credits.
3) Get the SCT hardware and hire Manuel to work with my tuner.
Kennett Square, PA
The other option is to have a dealer (or anyone with the tools and a Ford subscription can do it) program your PCM to whatever manual trans strategy you are using which will program everything including the ETC processor. I’d think that you would be able to use your existing HPT license but would be best to ask HPT about it.
6,410
8,310
In case you guys were unaware Jeff has some serious Ford cred going on. He was the engineer that worked with Phoenix on their Boss 302 program, among other things, so don't take his recomendation lightly.
