Autocross Data Acquisition
My current set up doesn't quite provide me with what I need...
I am using Torque Pro on my Android tablet giving me real time data on various parameters of the car (temps, RPMs, Voltage, etc)
I use my Iphone 11 for video with Track Addict
Dual GPS unit
Kiwi 3 OBD bluetooth interface
The problem is, I cant connect Torque Pro and Track Addict to the OBD, therefore not allowing me to get a full video with all the necessary information (throttle input, braking, G's, etc)
Are there any other suggestions? I like having the tablet, but starting to think my limitation is with the iphone only being able to bluetooth onto one device (Torque Pro)
Here is a video that shows the set up:
Solostorm is Andoird only, but will run easily on a cheap tablet. Adding a RaceCapture MK2 gives you a better GPS than the Qstarz thing and also ports some of the ODB channels into SS (steering angle, throttle, brake pressure)
I have been using autocross data since before the DL1 days (Gcube, Geez) and Solostorm is amazingly useful. It is a little harder to get super deep geek level data like with a DL1, but it is crazy easy to compare a pair of runs within seconds and see exactly what you want to change/try/etc.
DaveW
Latest lap times
