S197 BOSS 302 Race Car Build Thread Build Thread
8,736
2,747
VTBoss302 said:
Agreed.
The standard Boss valve springs are only "guaranteed" to 7500 (with a few hundred rpm safety "net").
Anything beyond 7900 rpm and one may run into trouble...
VTBoss302
VTBoss302
Yeah. I just adjusted the redlines down to 7800 (same as 302S) for a little more "safety". That's only costing me 2-3mph in each gear vs. 8K, but still gaining me 3-4mph in each gear vs. 7500.
8,736
2,747
Started the interior gut last night. Nothing irreversible at this point, but it's coming out! I only had about 30 mins to work, but things went pretty quick with the power tools I have now. The last couple Mustangs I gutted took a while with only hand tools. I've got plans for the weekend but I think I will have everything out of the car by the end of next week.
Does anyone know what this thing in the trunk on the passenger side is? (Aluminum support with black box)
Next week I may even get around to getting out the torch and scraper to remove the sound deadening goop. That should be "fun".
8,736
2,747
blacksheep-1 said:
BTW....60 bucks, that's pretty cheap insurance
http://www.roushperformance.com/parts/BOSS-302R-Valve-Spring-Kit-Ford-Racing.html
That's the same as what's in the car right now. I think I'll buy a set and freshen them sometime next year. Thanks for the link!
Just a guess, but the SN95s have the FPDM and fuel cutoff switch opposite of the fuel fill side. Only other thing I would guess is the sequential tail light electronics, but both are just guesses.
Are you going as far as removing the trunklid seal? That's one of the things I noticed was gone on the race cars, but would probably stay when I gut a car.
8,736
2,747
I will probably pull it and see how it affects the trunk closure (if at all). If the decklid doesn't rattle around with it out, I'll leave it out. I'm leaving the two big rubber stoppers on the bottom of the decklid.
JScheier
Too Hot for the Boss!
Pull it and see what the part # is on it. I'm not seeing it in any of the on-line parts diagrams... but it could be buried under 'bakery goods'.
8,736
2,747
Grant 302 said:
My plan for those two stoppers is to put PVC pipe over it, maybe 1/16" or 1/8" shorter to help stiffen them up and take loads from the planned wing.
Not quite sure if that will work, all the Tiger Wing installs I've seen use welded-in metal tubes to stiffen the decklid. The PVC might work in a static state, but I think it will fatigue and crack/fracture over time as it loads/unloads. That's my 0.02 anyways, with no real data behind it.
302S:
Yeah, if the PVC doesn't work, I'd tack on tubes for the same function and put a rubber edge on them. Definitely plan on similar bracing...more like what's shown on blue trunklid. Center of the wing load to right next to the stoppers.
8,736
2,747
Grant: I pulled the trunk surround foam and the decklid is not supported very well at all wtihout it. I put the surround back in.
Otherwise, I got to work getting pretty much everything out of the passenger side of the car:
Race shop is going to zip out the extraneous metal in the center of the door while the car is in for cage...need clearance for NASCAR bars on both sides of the car!
Separating out the unnecessary wires (window power & control, speaker, etc. I kept the locks and sensors so the dash cluster isn't constantly flashing "DRIVER DOOR AJAR PASSENGER DOOR AJAR" while on-track like it does in my buddy's '06 where we just blindly cut the door wire bundles.
Good to know. I'm impressed with your progress....depressed that I'm not doing the same yet! I need to find Boss 2.0 ::) 3.0 if you count my wife. :p
8,736
2,747
I was traveling this weekend (had a great time at a BIG Mini Cooper meet up in Jerome, AZ) so no additional progress on the car.
I did, however put together a basic scheme of how the car's livery will look when finished, minus a number of FORD RACING, NASA, and ProAutosports decals.
8,736
2,747
Stoptech makes good stuff but if I'm going to upgrade it's going to be to a Brembo Pro Kit, mainly for the 1" thick pads. Anyways that is NOT on my budget anytime soon since the kit is about $4K.
I would do a Magnum XL trans upgrade before that.
The stock brakes work very well with proper cooling, fluid, backing plates, and race pads.
With all those goodies they will certainly last longer...
The seals still tend to deteriorate rather quickly..
http://www.girodisc.com/Girodisc-Front-Caliper-Rebuild-Kit-for-S197-Mustang-with-Brembo-Caliper_p_6445.html
My extra 2 HP
8,736
2,747
My extra 2 HP
Good deal. Yeah these are definitely maintenance parts. My dust boots are only starting to show some very minor cracking; they have survived a long time thanks to those Titanium shims!
