Boss 302S SS Brake Line Replacement
I'd like to replace the SS brake lines on my 2012 Boss 302S race car. I believe the current ones are the original 8 year old Goodridge ones.
The connection to the calipers is unlike other brake lines I've seen before and I'm trying to find direct replacements for them. Anybody here happen to know the part numbers for these or where to buy them?
Thanks in advance for any help.
Here's what the front looks like:
And the rear:
8,733
2,735
This is what I use on my fronts w/ the Brembo XB105 calipers: https://www.amazon.com/gp/product/B000CIFW62/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I used generic Stop Tech brake lines for the S197 and cut the caliper-side (banjo) end off and attached the Aeroquip fittings. https://www.amazon.com/gp/product/B004HELWRK/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Hat tip on recommendation on both of those to @74mach
Looks like you can do it on the rear as well...mine is just a banjo back there but not a factory "S" car.
