Thank you
Dealer can do this, but I am sure they will charge you to do so. Takes less than a minute to do. If you can find someone local you could use their tuner even though it is not paired to your car. I used a friends of mine even though it was paired to his car.What if I need to a crank relearn but can’t get the sct tuner sent to me because it’s not legal in California?
Thank you so much you earned me some sleep this morning, so it can be any tuner then? Right?Dealer can do this, but I am sure they will charge you to do so. Takes less than a minute to do. If you can find someone local you could use their tuner even though it is not paired to your car. I used a friends of mine even though it was paired to his car.
And I can take off the check engine light as well right?Dealer can do this, but I am sure they will charge you to do so. Takes less than a minute to do. If you can find someone local you could use their tuner even though it is not paired to your car. I used a friends of mine even though it was paired to his car.
the People's Republik of Kalifornia... don't you have a family member outside of the state?What if I need to a crank relearn but can’t get the sct tuner sent to me because it’s not legal in California?
Yes, as long as that is what is causing the light. You can drive the car, just no WOT or high RPM's. Twice after I replaced the clutch or had to pull it I drove it to the dealer afterwards and had a tech I know relearn it there.And I can take off the check engine light as well right?
