You guys who are using dataloggers like the AIM Solo and others, how are you connecting them to your car's PCM (ECU)? Direct splicing or OBD connector?
Yeah, good advice!I have the OBD connector but you have to unplug it after your done with it. It won’t shut off.
Thanks, I haven’t had a chance to use it on track yet. I didn’t think just the down time between sessions could screw your day up.Yeah, good advice!
If you have a tiny battery like I do the wireless OBD connector will pull the battery down in the 40 minutes between sessions enough that the car won't start.....I try to find a paddock spot pointing downhill in case I forget.......or have lots of friends around. Right @carver?
I'm using a Braille B2015 battery and it's marginal, have to really make sure there are no loads on it during down time.
