badasbullitt said:I wanted to clarify that the skip shift connector is on the passenger side of the transmission. It is hard to tell from the illustration. Please correct me if I am wrong. There is another connector below that I mistaken as it and as I was driving I saw a low fuel warning flash up. I assume that is a fuel sensor.
2012YellowBoss said:badasbullitt said:I wanted to clarify that the skip shift connector is on the passenger side of the transmission. It is hard to tell from the illustration. Please correct me if I am wrong. There is another connector below that I mistaken as it and as I was driving I saw a low fuel warning flash up. I assume that is a fuel sensor.
Correct and all the way up top.
Do it and don't look back. The connector is up high on the passenger side of the trans. Unplug it, wrap it in tape and zip tie it so it's not flapping around.BrianDeTienne said:Man, I have to get this disabled. I have gone 1st to 4th on a few different occasions and thought it was operator error. ;D
Justin said:best way I have found to disable it is to just drive with the trackey lol
Only the 2012 Bosses have skip shift. You just unplug it and never worry about it again.MGCurry said:The 13 doesn't have I never had a skip shift?
jeepinocala said:The track key is the best way to disable it cause if yu unplug it and have any issues Ive been told by my dealer that it will have a code that cannot be erased and will void your warranty on the transmission.
