I installed my DSS driveshaft yesterday and seeing how it didnt come with instuctions thought I would post a how to on it.
Tools used:
Air Impact gun
8mm Allen socket
12MM 12point socket
10mm swivel socket
13mm swivel socket
10" extension
6" extension
15MM socket deep well
1. Jack rear of car up by its centersection on a level surface or lift the car up on a lift (release parking brake and take it out of gear)
2. If using a floor jack put rear of car on stands and let rear hang.
3. Using 15MM Deep well socket loosen h-pipe to axle tubes band clamps.
4. Pry the release tabs up so you can pull the clamps back to let the axle tubes hang.
5. Remove (6) 10MM bolts on the rear or the driveshaft to the rear axle using the swivel socket. use a different socket at your own peril I did on the first bolt and rounded it off in two seconds and took me 2 hours to get it off. Once off let the rear part of the drivesahft hang.
6. Using 12MM 12point socket remove the FWD 4 bolts on the drive shaft to the transmission. Once loose you may need to knock it around with a hammer to get it loose from the trans.
7. Remove the two 13MM bolts holding the center carrier bearing bolts. BE READY FOR 41LBS TO COME FREE!!!!!!
8. Your stock driveshaft is now free and ready to become a boat anchor. Remove it pulling it out towards the back.
9. Install the adapter flange using Blue loctite and 8MM allen socket (I used the impact gun and just hit them on full bore)
9. Slide new DSS shaft in from the rear the same way the stock came out but in reverse.
10. Reinstall the FWD (4) 12MM bolts again applying blue loctite or red (red will be harder to remove in future removals) ( I again hit it with the impact gun didnt use a torque wrench but I am sure there is a spec for it)
11. Bolt rear of driveshaft to the adaptor plate using the supplied 8MM allen bolts and blue or red loctite. Torque to 57ftlbs.
12. Reattach the axle tubes to the h-pipe and tighten clamps and knock down the tabs back in place.
13. Put full load on the rear wheels and take the supplied measurement that came in the directions.
14. You are now done congrats.
This is a how to so please keep the comments related to how to install it and not stray as to the merit of the driveshaft or anything of the such PLEASE! Start a new thread in the general forum thats what its for.
Tools used:
Air Impact gun
8mm Allen socket
12MM 12point socket
10mm swivel socket
13mm swivel socket
10" extension
6" extension
