S550 Elvira
+1 on changing the brakes! The regular 14 discs on the S550 are with the vents on the outside!! So you cant efficiently cool them with ducts. Any decent disc will have the vents opening to the inside. You really can't do much with those discs. One fellow I know bought the BAER 2PC discs in the OEM 14" size so as not to change the 4pot calipers, it worked ok but for the money, your better off going to the bigger 15" setup with OEM ford discs for nearly the same money. The 15" Brembos work really really well.
Can I keep the rear stock and swap front to prembo and do rotors with inside facing vents not exist for the stock brakes?
would pp underbelly be enough to redirect the air to the vorshlag deflectors?
would a pp underbelly fit the base model?
Yes, but it's not just the undertray. You have to change out the lip and some other parts.
We (Vorshlag) did it to our base model 2018.
All the part numbers and lots of pics are on the forum.
These are the part numbers and prices when we did it before the Rona.
  • Mustang PP2 front splitter, JR3Z-17626-AA ($410.60)
  • Mustang PP1 lower lip, JR3Z-17D957-CA ($200.42)
  • Lower Cross-Member brace, FR3Z-5025-A ($30.23)
  • Lower Cross-Member Bolt, W718025-S439, qty 6 ($1.56)
  • Insulator - Undertray piece, FR3Z-6P013-B ($24.05)
  • Under Cover Retainer Nut, W717220-S300, qty 4 ($1.56)
  • Mustang PP1 undertray (belly pan), JR3Z-17626-B ($95.74)
