Its about trying to get a more reliable engine for track use.
Gtorpedo runs a 7,500 RPM plus rev limit with more power. The new build has much better rods, rod bolts, pistons, and rings than OEM. It also should have a lot better quality control on clearances and be properly balanced.
This still doesn’t make sense to me. Yes, a built one is better. But what are the chances of the stock engine failing again? Probably low. Statistically speaking, it’s unlikely. For what the built engine costs, you could replace it with a stock factory engine twice..
