Fender liner delete?
6,563
8,222
50
42
California
For a time attack S550, is there any advantage to keeping the front inner fender liners? Are there any disadvantages to deleting them? Thanks!
You can mess up the aerodynamics by removing the fender liner. If you remove the fronts, it will let a lot of high pressure air to build up behind the fender. If you plan to remove the liner I would recommend you vent the fender to avoid the high pressure build up. I've heard rumors on other cars that removing fender liner hurts mpg.
65
34
Colorado Springs
Yeah I would definitely vent the fender and/or have fender cutouts. I wonder if venting the rear/side of the fender would be sufficient, or if the top would need to be as well.
65
34
Colorado Springs
Update for anyone curious:
