Ford announces Mustang GT4 at SEMA
Awesome. Anyone know the price?
6,572
8,564
Thanks.
Call me cynical but this is a GT4 spec car, which means you can ONLY buy parts from the manufacturer, this is a sure way to drive up the costs of racing IMO since you can't build one yourself, no matter how identical it is, it still will not have a homologation number on the chassis. I have no idea why US racing organizations are hell bent to adopt Euro rules packages other than it means less work for them.
We already run a Porsche that's built this way, it's extremely expensive, it's not like you can buy one and build some knock off molds for the carbon fiber, every piece has a Homologation number, it also kills the creativeness.
I'm saying $250K at the low end.
I hope I'm wrong
8,739
2,755
blacksheep-1 said:
Thanks.
I hope I'm wrong
I hope you are wrong as well.
I know KohR built the reveal car, but it's possible that Ford could allow Multimatic to build them just as they did with the 302R cars; I'm not sure what the rules are for "manufacturer supplied" but that's basically the model for the Ford GT race cars, so I assume it would stick. If that's the case maybe KohR and/or Watson are still involved cranking them out too.
Even at 120K this would still be way out of my budget range so I'm modestly hoping that the body panels will become available through KohR so I can build a race car that at least looks the part in a few years, based on an S550 Mustang GT (for club racing).
Edit: Looks like Dean just replied to you--Multimatic will indeed build the customer cars.
VoodooBOSS said:
I noticed the car has a clutch pedal. I'm not familiar with the Holinger trans, can someone please explain how it works? Also looks like the car has the stock R front splitter with another splitter installed below it.
It's still a "manual" trans. Kinda like a motorcycle. You don't need to clutch in order to change gear but you still need to disconnect the trans from the motor while you're not moving otherwise you stall.
https://en.wikipedia.org/wiki/Sequential_manual_transmission
Looking trough Holinger website they should have used this one with the pneumatic shifter
http://holinger.de/showroom/sg3
8,739
2,755
With a sequential you can't skip gears but you can go up and down through them very quickly. They can also tie the paddle commands to logic so you can rip the downshift paddle multiple times and it shouldn't let it execute an over-rev downshift.
