Front sits higher after camber plate install
488
456
MD
Happy Tuesday!
swapped out camber plates yesterday and now the front sits a bit higher than it did before. Do you think reclocking the lateral arms (with suspension loaded) on the inboard side will help this? Everything else up front is a spherical bearing. On bushing is the lateral link and I remember Kelly at BMR saying to reclock all bushings after lowering the car.
1,250
1,244
In the V6L
Happy Tuesday!
It's probably not a bushing problem. The bushings don't have the strength to resist over 500 pounds of force from the weight on the front corners.
You didn't say what you were swapping from - did you start with the OEM upper mounts or with someone else's camber plates? Not all camber plates are a perfect height match to the OEM mounts, so even if the camber plates are installed correctly, they could alter the ride height. Also, if you had the springs out, it's possible that they are rotated from where they were and now they're not sitting properly in the spring seats. That could also cause the ride height to rise.
488
456
MD
Never thought about that. Thank you
488
456
MD
Thank you. Never thought about that the rotation of the springs but I swapped from Maximum Motorsport to MMR. And looking at the plates when they came in I thought they would increase the drop because they looked shorter
1,244
In the V6L
How are the springs sitting in the lower spring seat? It's made with a spiral shape and the cut end of the spring spring has to be pushed around into the end of the spiral or it'll raise the spring up relative to the strut.
488
456
MD
That’s makes sense. I appreciate you trying to help but it may just be the way the plates are. I will say I have very little to none camber. I haven’t gotten an alignment yet but I doubt more negative camber will decrease ride height. I took the struts off and I had my mechanic swap the camber plates. He has worked on my car for years and I did inspect his work. Not much to miss but everything was installed correctly. I don’t think you can mess up much putting everything back on the car but I was careful in doing so. I think it’s just the way the plates are. Waiting to hear what Mark at MMR thinks. Car drives perfect (barring alignment) and I don’t hear anything abnormal.
thanks for the ideas.
