Fuel Pump Order help
The easiest way is getting the Motorcraft PFS1314 as it's the whole unit so it should be plug and play.
Otherwise you can go aftermarket with Walbro, Automotive, Deatschwerks, etc.. but there would be some wiring and plumbing to be done if you want to save some $$$.
PS : Where're you from Switzerland? I'm from Jura.
@Swiss Boss
Bern ;)
Do you also drive a GT350?
With PFS1314 for 474$ is everything included?
The PFS1314 has "without gasket" written in small letters.
Do I still have to buy the CG816 for $11, Or is that something else?
Cool.
I have a Boss 302. Maybe someday I'll get a GT350. They're nice car.
Yes it include everything. Here's the info from Tasca
The gasket is a big oring, unlikely to be damaged but since it might not be easy to get it in Switzerland I would get it just in case.
