- 6,563
- 8,221
- Exp. Type
- W2W Racing
- Exp. Level
- 20+ Years
Re: Going 18x11" Square with 305 Tires and Rotatable. It Can Be Done!
You got a 12" rim with a 58 offset on cortex rear outboard coilovers?
Thats almost 9" of back spacing...how did you get it to clear the shock?
What tires were you running?
Is that the setup in your sig pic?
@neemaneema said:12s are possible but you need: 1. Cortex offset struts, 2. a 20mm spacer up front if square offset desired, 3. camber. The fronts will be aggressive; camber is a must.
I ordered mine in et38 front/et58 rear. Still haven't gotten around to mounting them up.
