Going Square, what is needed?
I just called Rehagan and they're apparently out of the 18 and 20 mm 05-09 sway bars. Anywhere else I can get one or both?
I was hoping Rehegan would have it!
Maybe we can try cortex and Watson racing as well, or post a WTB thread on SVTP forum. As a last resort there are a few take-offs on eBay, but not priced very reasonably.
Tucson 302
2013 Black LS #439
I bought my bars from Cortex, but they sent me the wrong front bar. And when they sent the right one it came from Tire Rack so maybe try them too.
I bought mine from newtakeoff over amazon a few days ago.
http://www.amazon.com/gp/r.html?R=VFGIKDNG5UU7&C=3TG14KBDH777U&H=EIBGVIFLM2WAQMTUM0RXR0MPBOQA&T=C&U=http%3A%2F%2Fwww.amazon.com%2Fdp%2FB000O0X81Y%2Fref%3Dpe_385040_30332190_TE_3p_M3T1_ST1_dp_1
I wont be home before Sunday to be able to mesure the bar I received.
But according to the Ford part number, it's look like the 20mm from the GT. I think the V6 didn't have any bar for these years
The link worked for me but it doesn't state what size. $70 delivered.
Awesome. Just ordered one. The 20 or 18 mm would be fine with me. I have a Strano front bar but have not ordered the rear due to rubbing issues with the Whiteline relo brackets. Can't wait to put that power down coming out of the turns now. Once you relieve yourself of traction control, you truly understand the gentle dance, between throttle and steering, required to keep the back inline. I was very tempted to remove the bar, but this will do nicely.
5,255
4,248
Re: Going Square, what it needed?
ArizonaBOSS said:
I run 305 Pirellis on the SVE Drifts and the Roush wheels, both 10" wide. They will work.
I was about to push the button on a set of Nitto NT555R II 305/35-18 tires with SVE Drift 18x10 wheels. My Boss has the P springs and -2.4 camber, can I get away with a 3mm spacer or should I go with 10mm to be safe?? (Is their anything wrong with making your own spacers??)
I have seen comments on BMO about spacers ranging from 0 to 10mm for the Drifts!
Just installed the sway bay I received from the amazon vendor. Like Swiss Boss mentioned, I only had to re-use the side brackets.
Just in case someone needs it, the torque specs for the side bushing bracket bolts are 52 ft-lbs and the endlink bolts are 85 ft-lbs.
Removing the wheels made the installation a little easier, gave a little bit more clearance or the wrenches.
Here are a few pics.
Comparison. Top stock, bottom 05-09 GT
Stock
05-09GT
Everything done!
I put the rear shocks back to 5 from 3. But I won't really notice the difference made by the sway bar until at the track. I'm looking for a more planted feel during corner exit, while on the throttle.
NFSBOSS said:
Samo, was your rear axle originally painted black? In for you update.
Yes :(
I had an accident a while back, hit a curb and bent the axle housing. Unfortunately, I noticed that the dealer replaced it with a regular housing a little late and did not want to go through the hassle of bitching them out and having the car at the dealer for a few weeks. Another reason why I dont trust dealers... even when they say they ordered the parts off the vin :'( But I'm trying my best not to get bothered by little things like this, life is too short! 8)
F.D, I went with 20mm rear and the best result ( feel) I saw was with 5/5 dampers settings with camber of 1.5-1.6.
I think if you have more aggressive negative camber, starting with lower settings at the rear will be a good start. But then again your sway bar is only 18 mm.
Waiting for your impressions!
Thanks for the tip! Although, I still haven't invested in camber plates, so I'm still on stock alignment.
I drove the car all weekend, one major improvement I've noticed was that the rear end is more planted during turn-in, but I suspect that is mainly because the shocks are now at 5/5, compared to 5/3 when I had the stock rear sway. I've also noticed the rear end doesn't slide as easily when getting on the throttle a little aggressively during a slow turn. Two more weeks until the next event!
It is more planted because you soften the rear sway bar.
