GoPro Hero3 Black Edition w 32gb + 2 Mics + mounts + etc
For Sale:
GoPro Hero3 Black Edition…..
Has all the hardware that came with it +
HERO3 Black Edition | Wi-Fi enabled | Most Advanced HD GoPro Ever
32gb Patriot Memory class 10 MicroSDHC card (this is not your normal slow card) ….
Audio Technica PRO24CM Powered Microphone
Audio Technica ATR3350 Powered Lavalier Microphone
GoPro Suction Cup Mount
GoPro The Frame
GoPro Replacement Housing (extra)
GoPro External Mic Cable (2 of them)
Suction Mount for the PRO24CM Microphone
Asking 550$.
Plan was to use the second waterproof case and drill a hole for the Audio cable. Thus the lens of the camera is protected but you can still hook up the external Mic. Yes you could have used the skeletal case, but it has quite a few more holes and my way minimizes dust etc.
This should be everything.
Go Pro
Frame
Suction Cup for Pro24 Mic
Pro 24 Mic Bag
Pro 24 Mic
1x Go Pro Case
1x External Mic Cable
Go Pro Suction Mount extension swivel piece
Go Pro Wireless Remote
Go Pro USB cable
Go Pro Suction mount with Attached second Case
2x Go Pro Case open backs's
1x Case of 2x Go Pro Adhesive attachments (for use with the quick lock/release stuff)
32gb Patriot Memory class 10 Micro SD Card
6foot Microphone extension cable
Wireless remote Charger
Go Pro quick release pieces
Various Go pro extension/ turn pieces
Audio Technica Lavalier mic
CLose up of Go Pro Hero 3
Suction Cup for Mic
Wireless Remote
Close up of Memory Card
Lavalier Mic
3m Backed quick lock/release brackets
Larger Frame. Incase you get the lcd backpack or extra battery
Lens cover for when using frame
2 more quick release bracket things.
I'll actually throw in this little bracket my friend made for me. He made it on my request specifically so I could mount the Pro24CM mic directly between the exhausts and out of the air stream.
It can also be reversed to have it lower and also used for the Go pro itself keeping it directly centered.
