Gt350 charging problem… need help
Hello!
I have a 2018 gt350 with 20k mi
So I got a charging system service now error, battery won’t charge, so I replaced it. Then the voltage won’t go above 14 v and drop to 13 when throttle hard. So I replaced alternator
After reset bms, voltage is constant between 13.9 and 14.1 but I still got two codes p065b p0626
Error will go away when throttle hard
Help needed… thanks
Not sure if this would have anything to do with your situation but have you tried disconnecting the charging sensors or whatever they call them? The rings around the battery cables, they monitor current for smart charging. Removing them tricks the system to run the alternator at 100% and not allow it to throttle back.
I thought they both were battery temperature sensors? That’s what I read from diagram Lol I could be wrong
I’ve not looked at them on the diagram, rather seen a few threads on other sites of people with charging problems removing them and getting a constant 14+V. A few people followed up saying that they’ve done so for years without issues but of course there could be a risk so YMMV.
1,253
1,249
In the V6L
Hello!
Help needed… thanks
I had the same gong-show and screen display - "Service Charging System" messages. Swapped in a new battery, things went quiet for a while, then it came back. At the dealer's now getting a new alternator.
