I like it. It appears they made some custom fittings on the one end or is it both? I'm still waiting for Ford to fix my car but I might do this immediately afterwards. Do you know if this shop is working on a larger oil cooler?
btaylor101 said:I'm not very mechanical, so I was curious on why this solution is better than the Ford replacement. Looking at the two solutions it appears that Ford is overly complex with more points of failure. My concern is that the new solution is to simplistic. Any help on understanding the differences between the two solutions would be greatly appreciated. I've missed one track event so far this year and if I can find a better solution that can be delivered quicker, I am up for it.
50Deep said:Down side is the recall branding will still be on your vehicle until you get the specific revised hoses installed by a ford dealer.
This will be a great option once you've already had the dealer install the revised parts.
VoodooBOSS said:I like it. It appears they made some custom fittings on the one end or is it both? I'm still waiting for Ford to fix my car but I might do this immediately afterwards. Do you know if this shop is working on a larger oil cooler?
shelbyman1 said:Yes I totally agree with you that you HAVE to have Ford do the recall. So I'm probably not going to do anything until after that has been done....IF they ever get around to it. :
VoodooBOSS said:My last track day before the recall I saw mid 260's. It was 100 degrees out with low humidity and at sea level.
Mine's going tomorrow and I'm expecting drama around my CF splitter.
