S550 GT350R Race Car Build Build Thread Profile - S550 Mustangs
1,937
2,038
Michigan
A bit more info on the build. My initial weight target was 3,200lb, so 3,140 was a pleasant surprise.
Main areas of weight reduction were CF Roof and Hood, fully zipped OE Doors, lots of Body weight reduction, plus custom side exhaust together with lighter weight Long tube headers:
Lots of parts were on backorder, so I spent a lot of time stripping all the harnesses to eliminate unused circuits, hole drilled a whole load of things and even shortened some hardware. Also shortened cable runs for Master power solenoid.
Installed a 22 gallon Fuel Cell. F/R balance is improved 1%, even with no gas:
I'm still dialing the car in, but back to back tests suggest it's a little quicker in ST2 trim. It will certainly be a lot quicker, un-restricted and without ballast!
I have a couple more upgrades coming that should help further....
1,186
2,191
SoCal
Wow! I guess up until that last pic with BOTH cars, I was under the impression that I was reading updates on the grey car - this is a whole other car???!!! Very cool.
768
1,150
TX
1,937
2,038
Michigan
Hey Nick - Do you happen to have anymore details on that exhaust? Underside/inside shot how you routed it?
What was the driver for it? remove the heavy mufflers in the back? How come single exit vs. each side? Okay, I'll hold there :)
Several drivers:
Less weight
Moves heat source away from Fuel, Diff and Axle UJ’s
Easier to remove for maintenance.
Single 4” outlet flows as well or better than dual pipes and is lighter.
I didn’t take pictures and it has to be boxed in to reduce cabin heat. I ran without for initial shake down and wouldn’t do it again!
Downside (for some) is it requires a Fuel Cell to package and it will not meet sound at restricted tracks.
yotah1
Ford Employee
386
598
Detroit
Saw your new car on display at Mustang ALley during the Dream Cruise, nice build, lots of good ideas and a very clean car in the end.
I was a bit surprised you didn't move the fuse box and battery in the passenger seat area and the trunk as is usually done on the GT4s.
What's your weight balance in the end?
6,559
8,213
Is there a muffler or is this open exhaust?
1,937
2,038
Michigan
Thanks.
I didn’t think it was worth the work to move the battery. It only weighs 6lb. You end up adding a lot of cable weight and complexity…..
I’m using striped down OE harnesses so relocating the fuse box would be complex.
F/R is 53/47 with no gas and 51/49 full. That compares to 54/46 for the grey car.
6,559
8,213
It’s open. There’s plenty of space for resonators, but adding a muffler would be challenging.
There’s only one track that I run with noise limits, so I’ll use the Grey car there….
Yeah, that was my problem too, no room for mufflers and every track we run requires them, and they have to be very quiet.
I could have made a trombone in the back with a 4" muffler across the back seat area but the heat, weight and complexity just wasn't worth it in the long run. Thanks for the reply.
Frank.JD.Perez
FJD Performance
314
490
Pleasanton/Hayward, CA
where did you get those ford performance parts decals from?
