Has anyone used RaceCapture or any other CAN-bus data loggers with 2020+ mustang?
I have the RaceCapture Track Mk3 that I use on my 2017. Just OBD 2 port and I get all the info. There is a preset available for our cars to also get coolant temps, brake pressure and steering angle.
Edit to add: just saw that you asked about 2020+ specifically. That I’m not sure. My apologies for not reading thoroughly
captdistraction
GrumpyRacer
the OBD2 connector should still work for a can bridge - when you splice in on most fords, its into basically the same wires.
I hadn't touched any 2019+ cars with RC, but even if the older S550 preset doesn't work, its not terrible if you have a helper to do some CAN sniffing to reverse engineer wheel speeds, steering position, TPS and maybe brake pressure: https://www.autosportlabs.com/rever...tle-position-brake-pressure-and-wheel-speeds/
Yeah the problem is the old cars has HSCAN 1 and HSCAN 2 read through the 14 and 6 pins. Then had MSCAN on 3 and 11. Now HSCAN 1 is on diag 1 (14,6) and HSCAN 2,3,4 and MSCAN are on diag 2 (11,3). Connecting to both busses is fine, just messy. Do any of those CANcrocodile things (contactless CAN connectors) function with the mk3 RaceCapture?
*edit: ABS module with steering, brake pressure, wheel speed, etc is on HSCAN 2 btw
captdistraction
GrumpyRacer
I would hop on their forums and see about the can croc setup - I've never seen that before and certainly an interesting approach.
I'm on an old S197, thus my life's easy, just in on 14/6 and using the bridge built into the OEM cluster if I want to sniff around the MS bus (which on S197 all the interesting stuff is on HS-CAN). S550 is a bit more complex since there's at least 3 variations - much is still on HS1, but with some of the newer cars some of the modules have moved their way to HS2-4. S650 adds encryption into the mix for some data streams - I can't imagine how that's going to work for those cars.
I guess one thing would be to see how much of what data you want is on HS1 before spending a ton of time trying to connect to the other busses.
Latest lap times
