Hood pins
Can someone help me with pictures of where you mounted your outer hood pins?
I just got my Tiger racing hood and was install the pins and it seems every where i look there's no clear way to mount the stud.
Any help would be highly appreciated
You mount the studs in the rubber bumper stop location. You remove the stop and insert the studs. I believe in most cases you need to weld the threaded mount under the cross member.
