Hoosier A6 "Sticker" Tires in Size 295/40ZR-18 FOR SALE!
4 sticker Hoosier A6 tires in size 295/40ZR-18 for sale. These are brand new, never mounted sticker A6s in a great Boss 302 size that Hoosier no longer makes. I can't use 'em, but maybe you can. The A6 is probably the stickiest R-comp tire you can buy. Although they are optimized for autocrossing where you need quick tire heat buildup (it is the #1 tire choice of nationally competitive SCCA solo racers), they are also perfectly suitable for road race and track day use (although will wear/heat cycle out more quickly than the Hoosier R6 road race compound tire).
Fitment note: With the right wheel width and offset combination these tires WILL FIT a '12 or '13 Boss 302 both in front and rear on at least a 9.5" and preferably 10" or 10.5" width wheel with +42 to +47 ET offset. You will need to grind off the front sway bar top mounting bolt flush with the nut to avoid sidewall interference. Also, if running more than 2 deg neg camber using camber bolts with a +47 ET offset wheel, there may be very slight rubbing of the tire sidewall on the front strut tube, so you may want to run 5mm wheels spacers (with camber plates you shouldn't have this issue). Depending on your specific wheels and setup, though, your fitment may vary slightly. No guarantees here!
$800/offer for the set (buyer pays shipping). Please PM me if you are interested. Thanks!
Note: I have these listed for sale locally on Craigslist too.
Latest lap times
