Hoosier R7’s on what rim size
Dave_W
1,011
1,322
315 on 11 is completely fine. Will another 0.5 of wheel width give the tire marginally more support, yes. Do you have the experience to utilize that marginal increase in grip, that may be worth a tenth or two a lap? Your decision.
EIGHTLUG
https://www.archetyperacing.com
Supporting Vendor
I run them on 19x11.5. They feel great, look great, shoulder wear is mitigated, temps across the tire are rather even. Your -camber plays a part, too. The 315 R7 is measurably wider than a 315 Cup 2. 315 Cup 2 has a stretched sidewall on my 11.5" wide wheel. The R7 in 315 has a square sidewall.
5,263
4,261
Thats odd... the 315/30-19 Cup 2s should be about 0.2 inchs wider then the same size Hoosiers. Always thought the Cup 2s ran wider and that was part of the magic.
8,507
8,549
Tread width for the PSC2 is 11.5 and the R7 is 11.8 , per the tire spec chart for one of our favorite links on the TMO site ---- Tire Rack. So, yes , The Who Sure is wider than the Cuppa Too!
EIGHTLUG
Supporting Vendor
[/QUOTE
For comparison’s sake. Both on 19x11.5” wheels. The Hoosier is noticeably more square.
EIGHTLUG
Supporting Vendor
And just for fun, and to show you that tire spec measurements are about as believable as a persons info on a dating app, here’s a 305 Goodyear Supercar 3R next to a 315 Hoosier R7 (which my previous post displays is visually wider than a 315 Cup 2).
Dave_W
1,011
1,322
From Tire Rack (who use the same standard method to measure each tire themselves), specs section, 315/30-19 measured on 11" rim.
Michelin Pilot Sport Cup 2 $433 ea.
treadwear: 180; section width 12.6"; tread width 11.5"; diameter 26.5"
Hoosier R7 $507 ea.
treadwear: 40; section width 12.5"; tread width 12"; diameter 26.1"
Looks like I took too long writing this - multi-tasking too much. As pictured above, the "standard" tire size printed on the sidewall tends to be more of a vague representation of actual tire width when dealing with competition-type models.
8,507
8,549
Thanks Dave W, as I had been doing spec data at Tire Rack concerning Toyo RRs, which have some major advantages in Time Trial and Road Racing Classifications with NASA and I accidentally put the tread width down for the 315/30/18 ( size I have run with Hoosier and BFG ), instead of the 19 diameter R7. I knew they were wider than the PSC2s , but I also like that tire quite well when recommending something for folks who drive to the track.
1,250
1,244
In the V6L
Speaking of dating apps, I've got a date with the tires on the left. I have a set of four GY 3R's on 11" rims that I'm hoping to run at Area 27 in early September. They're the same section width as the MPSC2 315's and have the same rubber on the road (tread width minus voids) as Pirelli Trofeo R 325's. Here's hoping it doesn't rain...
EIGHTLUG
Supporting Vendor
If you haven't run the 3Rs before, prepare to be amazed. ...and how I would love to run Area 27 again. That track is amazing!
1,250
1,244
In the V6L
If you've run them, what pressures worked? The ZL1 1LE owner's manual says 35 hot - does that work on a GT350? Also, how is the life and heat cycles? Longer or shorter than MPSC2's?
im waiting to finish my sport cups to throw on my r3’s.....doing as many track days as i can this week 2-3 so i can get sc2’s worn out
6,423
8,331
Hoosier R7 Tires
SizeDiameterWidthRim
Range
Measured
Rim
Tread
Depth
Load
Range
Max
Load
Max
psi
WeightRevs/Mile
P 185/60ZR13
80W SL BSW
21.7"7.8"6-7"6"4/32"SL992 lbs44 psi15 lbs958Show Specs
P 205/60ZR13
86W SL BSW
22.8"8.8"5.5-7.5"6"4/32"SL1179 lbs44 psi17 lbs911Show Specs
P 225/45ZR13
77W LL BSW
20.9"9.3"7-8.5"7.5"4/32"LL908 lbs44 psi16 lbs995Show Specs
P 225/50ZR13
88W SL BSW
21.9"9.4"6-8"7"4/32"SL1235 lbs44 psi17 lbs949Show Specs
P 205/55ZR14
85W SL BSW
22.8"9.1"5.5-7.5"7"4/32"SL1135 lbs44 psi17 lbs911Show Specs
205/60R14
BSW
23.7"8.1"NANA4/32"NANANA18 lbs877Show Specs
P 225/50ZR14
88W LL BSW
22.9"9.4"6-8"7"4/32"LL1235 lbs44 psi20 lbs908Show Specs
P 205/50ZR15
84W SL BSW
22.8"8.5"5.5-7.5"6.5"4/32"SL1113 lbs44 psi17 lbs911Show Specs
P 225/45ZR15
81W LL BSW
22.8"9.3"7-8.5"7.5"4/32"LL1019 lbs44 psi19 lbs911Show Specs
P 225/50ZR15
90W SL BSW
23.8"9.7"6-8"7"4/32"SL1301 lbs44 psi20 lbs874Show Specs
P 245/40ZR15
83W LL BSW
23"10"8-9.5"8.5"4/32"LL1074 lbs44 psi19 lbs904Show Specs
P 245/50ZR15
95W LL BSW
24.4"10.3"7-8.5"7.5"4/32"LL1499 lbs44 psi22 lbs852Show Specs
P 275/35ZR15
82W LL BSW
23"10.8"9-11"9.5"4/32"LL1047 lbs44 psi21 lbs904Show Specs
P 275/50ZR15
101W SL BSW
25.5"10.8"7.5-9.5"8"4/32"SL1830 lbs44 psi24 lbs815Show Specs
P 205/45ZR16
77W LL BSW
23"8.5"7-8.5"7"4/32"LL908 lbs44 psi17 lbs904Show Specs
P 225/50ZR16
91W SL BSW
24.7"9.4"6-8"7"4/32"SL1367 lbs44 psi21 lbs841Show Specs
P 245/45ZR16
88W LL BSW
24.4"10.3"7.5-9"8"4/32"LL1235 lbs44 psi22 lbs852Show Specs
P 255/50ZR16
99W SL BSW
NANA7-9"8"4/32"SL1687 lbs44 psi25 lbsNAShow Specs
P 275/45ZR16
94W LL BSW
25.6"11.2"8.5-10"9"4/32"LL1477 lbs44 psi24 lbs812Show Specs
205/40R17
BSW
23.5"8.1"NANA4/32"NANANA17 lbs884Show Specs
P 225/40ZR17
81W LL BSW
23.8"9.6"8-9.5"8"4/32"LL1019 lbs44 psi20 lbs874Show Specs
P 225/45ZR17
84W LL BSW
24.7"9.7"7-8.5"7.5"4/32"LL1102 lbs44 psi21 lbs841Show Specs
P 245/40ZR17
86W LL BSW
24.3"10.3"8-9.5"8.5"4/32"LL1168 lbs44 psi21 lbs855Show Specs
P 245/45ZR17
89W LL BSW
25.5"10"7.5-9"8"4/32"LL1279 lbs44 psi22 lbs815Show Specs
P 275/35ZR17
85W LL BSW
24.7"11"9-11"9.5"4/32"LL1135 lbs44 psi23 lbs841Show Specs
P 275/40ZR17
93W LL BSW
25.5"11"9-11"9.5"4/32"LL1433 lbs44 psi23 lbs815Show Specs
P 295/35ZR17
89W LL BSW
25.3"11.6"9.5-11"10"4/32"LL1279 lbs44 psi25 lbs822Show Specs
P 315/35ZR17
93W LL BSW
25.6"12.6"11-12"11"4/32"LL1433 lbs44 psi28 lbs812Show Specs
P 225/40ZR18
83W LL BSW
24.8"9.5"7.5-9"8"4/32"LL1074 lbs44 psi20 lbs838Show Specs
P 245/35ZR18
80W LL BSW
24.4"9.9"8-9.5"8"4/32"LL992 lbs44 psi21 lbs852Show Specs
P 245/40ZR18
88W LL BSW
25.4"10.3"8-9.5"8.5"4/32"LL1235 lbs44 psi22 lbs818Show Specs
P 255/35ZR18
82W LL BSW
24.8"10.8"8.5-10"9"4/32"LL1047 lbs44 psi22 lbs838Show Specs
P 275/35ZR18
87W LL BSW
25.5"10.7"9-11"9.5"4/32"LL1201 lbs44 psi23 lbs815Show Specs
P 285/30ZR18
86W LL BSW
24.9"11.5"10-11"10"4/32"LL1168 lbs44 psi24 lbs835Show Specs
P 295/30ZR18
88W LL BSW
25.3"11.6"9.5-11"10"4/32"LL1235 lbs44 psi25 lbs822Show Specs
295/40ZR18
98W LL BSW
27.2"11.9"10-11.5"10.5"4/32"LL1653 lbs44 psi27 lbs764Show Specs
P 315/30ZR18
91W LL BSW
25.6"12.5"11-12"11"4/32"LL1356 lbs44 psi27 lbs812Show Specs
P 315/40ZR18
102W LL BSW
27.3"13.2"10.5-12.5"11"4/32"LL1874 lbs44 psi30 lbs762Show Specs
P 335/30ZR18
95W LL BSW
25.6"13.5"12-13"12"4/32"LL1521 lbs44 psi28 lbs812Show Specs
P 345/35ZR18
100W LL BSW
26.8"13.9"11-13"12"4/32"LL1764 lbs44 psi29 lbs775Show Specs
P 235/35ZR19
79W LL BSW
25.6"10.2"8-9.5"9"4/32"LL963 lbs44 psi23 lbs812Show Specs
P 265/35ZR19
86W LL BSW
26.2"10.4"9-10"9"4/32"LL1168 lbs44 psi24 lbs793Show Specs
P 295/30ZR19
89W LL BSW
26.1"11.5"10-12"10"4/32"LL1279 lbs44 psi25 lbs796Show Specs
P 295/35ZR19
92W LL BSW
27.3"11.5"10-12"10"4/32"LL1389 lbs44 psi26 lbs762Show Specs
P 315/30ZR19
93W LL BSW
26.1"12.4"11-12"11"4/32"LL1433 lbs44 psi27 lbs796Show Specs
P 315/35ZR19
96W LL BSW
27.3"13.2"11-12"12"4/32"LL1565 lbs44 psi31 lbs762Show Specs
P 325/30ZR19
94W LL BSW
26.8"13.6"12-13"13"4/32"LL1477 lbs44 psi28 lbs775Show Specs
P 345/30ZR19
98W LL BSW
26.8"14.1"12-13"13"4/32"LL1635 lbs44 psi30 lbs775Show Specs
P 245/35ZR20
95W XL BSW
26.8"9.8"9-10"8.5"4/32"XL1521 lbs50 psi23 lbs776Show Specs
P 265/30ZR20
95W XL BSW
26.7"10.9"9-10"9.5"4/32"XL1521 lbs50 psi23 lbs778Show Specs
P 285/30ZR20
99W XL BSW
NANA9.5-10.5"10"4/32"XL1709 lbs50 psi25 lbsNAShow Specs
295/30R20
101W XL BSW
NANA10-11"10.5"4/32"XL1819 lbs50 psi27 lbsNAShow Specs
P 305/30ZR20
103W XL BSW
27.1"12.2"10-11"11"4/32"XL1929 lbs50 psi27 lbs767Show Specs
P 325/25ZR20
103W XL BSW
27.1"13.2"11-12"12"4/32"XL1929 lbs50 psi28 lbs767Show Specs
P 335/25ZR20
103W XL BSW
