How Much Rear Camber Adjustment Is Available with Factory Components?
225
312
Virginia
I’m planning on installing MM camber plates and dialing in the *updated GT350R Ford Recommend Track Settings. I’ve seen that the MM plates offer enough adjustment up front but, does the factory rear allow enough adjustment to get to -1.6? If not, how much? I ran the factory street settings last season, is the track setting, a good starting point? Is it even worth adjusting the rear at this time?
Not sure what the max is but I’ve got -1.8 on mine now with stock camber arms and that’s in the middle of the slot. I’ve seen -2.0 on previous alignments and not had the bolt all the way inboard then either.
8,496
8,495
You want more than 1.6 up front , and you have choices( with M&M, Vorshlag, and the new Ford Camber Plates for the 19s that were standard on the R), but getting that in the rear should be ok. I had around 2.5 in the front with my camber plates when I had my 17 GT 350.
I use -2.0 in the rear and my GT350R is completely stock.
FYI I use -2.7 up front and that seems to work well. I recommend at least -2.5 up front. Honestly I’d go even more if I could, but the stock tolerance slop won’t allow my car to even with Vorachlag plates. the outside of my tires still wear quicker than inside at -2.7.
Full Tilt Boogie Adjustable Camber Arms & Toe arms
Ford Performance subframe and differential bushings
Ford Performance racing springs, firmer ride and lowers car approx 20 mm
Vorshlag caster camber adjusters
track setup
-2.5 degrees neg camber on front
-2.0 degrees neg camber on rear
2D3C5F00-46F6-42BA-BEA5-C5740E93CA9F.jpegC6B35614-2D11-42CA-8F12-21C7BEAD4079.jpegCCB1AC72-79CA-4F0C-B509-9153B4AA4BC6.jpeg98D3BC2E-8A18-4701-8CD9-55E63088D09D.jpeg9CD85E1C-F1A2-4A68-B9B2-E4ABD746066F.jpegC88DD014-1A44-4A49-A29E-64ABFF55AB18.jpegEC1D4A96-6F00-4E35-B41D-1A6A8C4FB358.jpeg14E47546-0078-4975-B1EA-02A24008A39A.jpegAEAE12F0-452B-4412-869C-3EB8F1B4D2DE.jpeg2156FFB2-9AC5-419E-9DDA-EB7113AD06E5.jpegD7CB28D1-0D10-4575-87BF-301895DC05CC.jpeg
