I did what I said I wouldn't - suspension parts are in route
cloud9
Gary
Here's the new Boss and some initial observations. First of all it fixed all the things I'd expect. It also feels like it's on rails.
1) There's virtually no brake dive anymore and I have track pads in and did some pretty aggressive stops.
2) You can turn right from a stop without tiptoeing on the throttle and there's no tire slippage.
3) Wheel hop is gone.
4) I hammered it coming off an on ramp over a very bumpy surface and the rear wheels stuck through the acceleration.
5) It is noticeably firmer and responsive, but not harsh like a go cart.
6) I couldn't find any significant body roll, but I'm on street tires. I ripped through several on and off ramps on the interstate and it still feels neutral. I won't know for sure until I get sticky tires on it on track.
Bottom line is the car is getting closer and closer to a race car but still VERY streetable. I hope this actually nets a reduction in lap times. I'm guessing it will, but until I get some seat time I won't know for sure. I'll also probably need to work through some adjustments. Currently I have the front bar set at full soft, front shocks at 2 and rears at 3 out of 8. This was the recommendation I got from Mark Wilson for a staggered setup from their testing. I also ended up with -3.1* camber left and -3.0* right, 6.5* positive caster and 0.00* toe left 0.01* toe right.
Uploaded with ImageShack.us
VoodooBoss
Rick
Thanks for the update. Now how much of what you're feeling is the springs compared to the rest of what you installed? Time to order the M-5300-P springs, camber plates and a panhard bar. ;D
Looks awesome, initial feedback is very positive! Yeah, that is another benefit of lowering a macpherson strut car, you get added negative camber in the front! :)
cloud9
Gary
Thanks for all the positive comments guys. I did take some measurements after installation if anyone wants to compare them to their Boss with the stock suspension.
Front splitter 5-1/2" above ground
Front fender well measured at wheel centerline 27-3/4" above ground
Rear fender well measured at wheel centerline 28" above ground.
VoodooBoss
Rick
I had already measured mine.
Front fender well measured at wheel centerline 28" above ground
Rear fender well measured at wheel centerline 29 1/4" above ground.
The bottom of the side of my splitter is 6 1/4".
cloud9
Gary
I remeasured the rear and it's closer to 28-1/8" so it looks like a little over a 1" drop. I expected about 1/2" in the front. Did you measure your front splitter at all? I don't have side splitters ;)
VoodooBoss
Rick
That was the side of my front splitter. It's 6" even in the front. Mine are measured with the stock Pirelli's on the stock wheels.
I expected about a 1/2" in front and 1" in the rear so we're close.
PeteInCT
Gary - looks sweet, I'm sure it's going to handle beautifully. Here's my numbers, not sure why my nose is so low but that may be why it feels so good in my last runs.
Front: 27 1/2"
Rear: 29"
Splitter: 4 7/8" (LS splitter)
Gary- How is the NVH in the rear? Same as stock, little increase, big increase.......???
Can't wait to hear the feedback after track use!
cloud9
Gary
I was surprised that I noticed virtually no increased NVH so far. I haven't driven it with windows up yet so I will try that today.
**edit - drove windows up and no radio (I never drive this way) on the way to the gym this morning. As expected, rear end whine and mild clunk (not clank) from the control arms is more noticeable. I have rod ends on all control arm connections with NO bushings. If you went with poly bushings you probably wouldn't notice any difference. It's still WAY quieter than my GT500 and far from annoying.....at least for me ;)
Sounds completely tolerable for the street. You know what the true test is..... Taking the wife out in it. Let us know what she thinks...
My wife HATES the car.....even in stock trim.....to flashy for her ::) I talked to my lawyer but he recommended I find another reason on grounds for divorce......
VoodooBoss
Rick
Front: 27 1/2"
Rear: 29"
Stock wheels or the PF01's?
My wife loves our Boss and likes riding around in it but she doesn't want to drive it. Only driven it once because I insisted. I guess if she wanted to drive it all the time we'd have a problem. :D
Latest lap times
