Jimmy Pribble said:I can't see any good reason to keep these unless you want your Boss Mustang engine nice and quiet.
And *this* is where I fail. :-\
steveespo said:i'm gonna buy the turkey pan (lets see how many real Ford experts are out there) for $80 and tell everyone I did a mod that got me 10 HP.
great idea where does one buy dry ice?NewBossowner said:Justin, Dry ice works well without the watery mess and lasts a bunch longer.
Well it has been a few years since I used this trick at the track but chemical houses, or gas suppliers ( welding supply ) used to carry it. I googled it and got a ton of listings for my area, so maybe that's the best way now. Wear gloves, do NOT touch with your bare hands. The burns are brutal.Justin said:great idea where does one buy dry ice?
thanks I think I seen it at a grocery store somewhere around here.NewBossowner said:Well it has been a few years since I used this trick at the track but chemical houses, or gas suppliers ( welding supply ) used to carry it. I googled it and got a ton of listings for my area, so maybe that's the best way now. Wear gloves, do NOT touch with your bare hands. The burns are brutal.
Brandon302 said:Couldn't dry ice crack something though? Or is everything so hot that it is only able to cool.
no thanks on the meth been there done that with my cobra. Cost me an engineSean said:Or you can use meth and drop your Intake Temperatures by 120 degrees. Dry Ice is probably cheaper if you don't go to the track very often though.
Justin said:no thanks on the meth been there done that with my cobra. Cost me an engine
NFSBOSS said:For fun I looked up the Cobra Jet and Boss 302 intake instructions at the Ford Racing website. For the CJ intake install there it no mention of the foam pieces being removed but there are photos of the foam pieces, page 10, and you can clearly see the foam pieces in place after the CJ intake is installed, page 21. They did not reinstall the fuel rail covers, page 38. You can download the instructions at the link below.
http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=22445
On the Boss 302 instructions for a GT there is no mention of the foam pieces and none are included in the kit.
What does this mean? I haven't a clue but like Scott stated it isn't going to hurt anything removing them.
honestly if you can find peel and stick heat shield sheet and just cut your own and get some quality edge tape your probably better off. Nothing elaborate about this kit really just rectangle with a slight angle cut on the fwd edge.NFSBOSS said:I never installed this on my Boss and had forgotten about this. I might at some point. If it's snake oil it's cheap snake oil and probably can't hurt.
http://www.summitracing.com/parts/hsp-140008/overview/
Thanks for the tip.Justin said:honestly if you can find peel and stick heat shield sheet and just cut your own and get some quality edge tape your probably better off. Nothing elaborate about this kit really just rectangle with a slight angle cut on the fwd edge.
