Largest spacer on ARP 1” Extended
Switching tires to Toyo RRs and they are supposedly a bit narrower than the BFG gforce R1Ss ( no longer made I the 315 size ) which slightly rubbed the struts. The issue is some 315s will likely fit with no rubbing and others might with a 25mm. Would think a 28mm would fit on the ARP studs and interesting to see the note listed by AZ Boss ----no wonder he has won the ST2 Championship with the NASA Region he competes in.
