- 380
- 2
Installed a set of T springs, LCAs (M-5649-S) and LCA relocation brackets (M-5650-A). Also installed an adjustable panhard bar, and running the stock rear sway bar.
I noticed that the new LCA relocation bracket and stock sway bar have virtually no clearance. I haven't taken the car off of the jackstands yet to drive it and let everything settle out. I also haven't played with the panhard bar adjustability (currently set at the length the stock one was at).
Looking at the picture attached, is this lack of clearance normal? Do I need to play around with the panhard bar to gain clearance, or do I need a smaller (thinner) sway bar? I want to run a smaller sway bar than stock eventually, but if I can get away with doing a track event or two with the current setup that would help my budget a little bit.
