- 6,415
- 8,325
I like the way that spliter turned out! Will be trying to make one this week along the same lines...
Exactly what I mean! Gotta account for all dynamics and travel...
Do it! Take note of his update with the spats covering the front wheel well and apparently stabilizing it structurally.
Mount it as low as you dare... and especially if you're running the 500# now instead of the 550# fronts.
What kind of scrub were you guys observing after this thing came off the track?
Was it on the front, rear, or even across the entire splitter?
What was your thickness before, and then after the race? I’d be curious to know just how much you were scrubbing off.
Honestly, the car looks like it’s about where it needs to be. When I was racing, we’d shoot for a ride height of 1/4” off the surface (using bump stops to stop from hitting the track) and end up losing about 3/16” in thickness where we would make contact.
Been way to long ago to remember, you gotta understand, AJ was making spring adjustments in as little as 15 pound increments, same with everything else tweak here, tweak there, his strongpoint besides being able to find the gas pedal, is being able to come in a ask for specific, precise adjustments, (or doing them himself) and you have to remember when you set a splitter or wing angle it has to be with the car at ride height, which is not necessarily where it ends up at the track, you have to take in consideration rake angle and dive.
The absolutely biggest mistake I see in the land of splitterdom is guys not sealing the splitter to the body, not only does this kill a bunch of downforce but it can cause the splitter to collapse, if it gets under the front tires under braking you are going for a ride..
Hence..gorilla tape was invented.
ThanksClean up that tape!!
Believe it or not, that shiznit will buffer and hurt you if it’s not smoothed out!!
Your silocone job is PERFECT!!!!
