- 6,429
- 8,336
it's like anything else, if you're going to beat the crap out of it, you need to over maintain it Spacers, on the right studs have never been an issue for me, or any of the cars that I've worked on
Just one of the examples what happens when spacers fail on track.
I've used both types (adaptors and spacers) never had had either fail. So for me, yes it was worth the risk! I of course, torque and re-torque the lugs often on both types. Like others have said, it is a wear item just like tires, brakes, etc. There is risk in any part on your car. Just my opinion...
I'm still confused about Ontario/Canada's spacer law. Do they go around parking lots looking at your hubs or something? Do they pull you over and ask if you have spacers? Yes, some are obvious, like the super camber folks. But on well setup mustang you cannot even tell there is a spacer - mine just look like it's part of the hub. This is me mostly just attempting a joke, but I suppose I am a bit curious to how many "spacer" tickets they give out.
Hey Bill I do understand that longer studs work however considering how often at least my Mustang is going through wheel hubs I just think changing wheel studs so often is a problem. Here in Bulgaria rotating tires is not a big consumable so for my personal car I decided to go with ET26 19x11 front in order to A) not use wheel spacers because I don't want additional things that can fail on my car and B) I can still rotate tires. Maybe eventually will move to longer wheel studs, spacers and ET52 wheels up front but we will see how this season develops. I'm just pointing out that last season 2 such failiures (obviously on different cars than Mustangs failed) here a lot of drivers also use ARP studs on different models of cars and slip-on spacers but as you can see from video and photo evidences this still fail. Lug nuts I understand is a wear item and I'm on my second set. Regarding photos and videos check out my build thread lot's of videos from my local track. I plan to visit few more tracks near me like Nurburgring, Red Bull Ring, Spa, Hokenhaim ring this upcoming season ones the situation with travel improved. Have lot's of friends that are doing this tracks and we have a Bulgarian Carrera Cup / Germany GT4 racing team and the top driver is a friend of mine who is spending time teaching me when he can. With that in mind I'm excited to see how a set of 19x11 wheels with 295/30 tires will transform the car. Currently driving on 275/35 square.Dear bnight,
Please continue to post as we value members on TMO from other Countries and I hope you realize that some of the folks here are middle aged, old or in my case ancient. The concern with a proper spacer (OP spacer ) is not with the spacer itself, but with the studs. As an ancient racer I have seen many folks use standard length studs and install a spacer over them, lacking enough stud length. This is why the older members on here are really stressing the issue that an ARP stud ( both strengthened and lengthened) is the only way to go for the track. Blacksheep 1 is the tire and wheel Guru for some very well known ( in the US ) racing teams and he has used enough long studs that he has become a Stud himself, ha. Seriously, most of us older members have used these aircraft grade long studs for years with no trouble and we use spacers. We are trying to show folks the reason longer studs are necessary to use with spacers. Your videos could be examples of what happens with standard, short studs.
Post more pictures when you go to a race track and a video would be cool if you have that capability? What track do you run in Bulgaria and have you raced the Mustang in other Countries near you?
For the past 2 season I was running Chinese regenerate semi slicks made by Zestino in 275/35/19 and they did hold really well one set lasted 225 laps which was insane. And my current set lasted me 5 track days and by the look of it it has another day or so left in it. For next season I plan to go with same tires but in 295/30 in Europe we are very limited in terms of semi-slick tires and most options are insanely expensive other option I'm considering is Nankang AR-1 in 305/30 which may be better but not sure on how long it will last.Sounds like you have some fun tracks to go to and the increase in tire size should help, but what brand are you running?
I'm happy with the Zestino's for sure but I'm sure the Nankangs will just be better. Other tire I'm considering is A052 by Yokohama which is also available in Europe and the others are the obvious Cup 2's and Goodyear Supersport R and Toyo R888R. Overall very limited choice of tires and since it's a square set choosing something that is easy to source and often is important. Still have few more months to decide though.Those Zestinos are quite popular down here as well. Seem to last forever and the lap times are decent considering the long life they get. But I would think the Nankings will be faster.
I think that is another user error. Some systems demand more maintenance. "loose" is what breaks studs. I see guys with type 2 spacers at the track diligently check their lugnuts before they go out on track yet they nevr take the wheel off to check the nuts on the spacer = fail. I have seen the same lugnut checking on screw-in stud hub cars like the bmws and mini cooper but no one takes the wheel off to make sure the stud if fully torqued to the hub. These come loose all the time.My understanding is that thread-in aftermarket studs break a lot more than the factory press-in style studs which are on our Mustangs.
that is actually a good video and makes a lot of good pointsIf you use wheel spacers, you really should watch this. James Clay, professional driver for Bimmer World's IMSA GT team, talks about checking the fitment of each wheel spacer to each wheel.
