Looking for A How-To: Traction Lock to Torsen Swap
USA
I have a base GT that I want to swap an OEM Torsen into. I’m having trouble finding a local shop that will do the work, so I’ll probably have to do it myself. Are there any step-by-step guides to doing this? I haven’t been able to find one so far.
1,186
2,195
SoCal
Are you changing the gear set too, or just swapping the differential?
1,186
2,195
SoCal
Just follow the disassembly and reassembly instructions from the Ford Service Manual. Since you’re not changing gears, there’s less worry about having to adjust shims for backlash and gear pattern. No need to do anything with the pinion, which saves a lot of work. Pay close attention to what shims are on which side, and reassemble exactly as it comes apart. You’ll want to check backlash and gear pattern before you button it up, but high likelihood it will be in spec.
Here’s a link to the Ford Service Manual:
https://iihs.net/fsm/?d=759&f=Differential Carrier.pdf&p=1
