- 6,430
- 8,338
so, I had to get the yellow mustang teched and i needed a fuel sample port. There was one on there.. sort of.. but was down by the exhaust, and was not easily managed. The tech guy suggested I call Pegasus Racing.
The hi zoot tees are very expensive quick disconnect pieces, and I'm just a low buck guy, so here's what we did.
down by the block was an existing tee, possibly factory, not real sure, I plumbed into this with a steel braid hose
I then installed this bit of genius, a viton sealed nipple, that you can compress and it will allow fuel to flow out of it
I then installed another tee so that I could dump the fuel away from the hot engine compartment, the extra port is to install a fuel pressure gauge for diagnostics
I have $40 in the whole thing, not including the mysterious lower tee.
