"Man Down" - Lost Bosses
dean_acheson said:
Man, just scrolling through this thread, there have been a lot of these cars wadded up! I wonder if it tracks the first generation of cars in their first few years.
I would bet more were wrecked back then. Ours have far superior brakes.
jneary said:
Hmmm, they must have had a challenge with the Boss cars early on as that VIN is pretty low compared to mine. I wonder if they had a stack of them sitting around with some technical issue which held them up. Doesn't seem to make sense that the VIN number is lower but the Boss build number is higher.
John
Didn't they hold up the cars because of the stripe issue?
Salvage 2012 listed on ebay;
http://www.ebay.com/itm/Ford-Mustang-COUPE-2012-ford-mustang-boss-302-wrecked-salvage-rebuildable-damaged-runs-tons-of-susp-/151282242344?forcerrptr=true&hash=item23391fd328&item=151282242344&pt=US_Cars_Trucks
Saw this on my way home the other day! Not sure how he got up there. Can you say "front end alignment".
FullSizeRender_zpse6291db9.jpg~c200
1,485
412
Hardly any Bosses have been declared a salvage title, if you compare them to the FGT's. From what I understand, something like 40% of the FGT's have salvage titles.
On the list already but back for auction 5 months later
Comes with 3 BOSS wheels and a roller to get 'round the yard.
http://www.ebay.com/itm/Ford-Mustang-Boss-302-Coupe-2-Door-2013-ford-mustang-5-0-boss-salvage-wrecked-rebuildable-grabber-/151461292746?forcerrptr=true&hash=item2343cbeaca&item=151461292746&pt=US_Cars_Trucks
2013 Bosses
This post has been moved here as I have hit the character limit for the original post.
For 2012 Bosses, HERE:
Boss #0072 VIN 1ZVBP8CU6D5200338 - GHIG - Major right front body and suspension damage. Drivers airbag deployed. GA July 2013
Boss #0065 VIN 1ZVBP8CUXD5200505 - School Bus Yellow - Flood damaged - VA Aug 2012
Boss #0069 VIN 1ZVBP8CU7D5200672 - GHIG - 6900mi. - Light damage to front bumper beam, forward frame rails, driver's side airbag deployed, likely rebuildable, up for auction in TX, Sept 2015
Boss #xxxx VIN 1ZVBP8CU1D5202062 - School Bus Yellow - 18987mi. - Heavy LF damage, both airbags deployed, up for auction in AR, August 2014, still available as of April 2015
Boss #xxxx VIN 1ZVBP8CU7D5202177 - School Bus Yellow - 13754mi. - Louisiana hurricane flood damage - dash operable - TWIN TURBO setup, engine no start - no airbags deployed - up for auction in LA, Nov 2017
Boss #xxxx VIN 1ZVBP8CU4D5207059 - Performance White - Canadian car - sustained significant driver's side damage - up for auction in Ottawa November 2012
Boss #xxxx VIN 1ZVBP8CU4D5208731 - School Bus Yellow - 12100mi. - right side damage to door and lower frame rail, possibly repairable, up for auction in GA, August 2014
Boss #xxxx VIN 1ZVBP8CU8D5210854 - GHIG - 7000mi. - Flood damage, immersed up to windows, powers up but engine not functional, up for auction in gulf Coast area, April 2015
Boss #xxxx VIN 1ZVBP8CU4D5223312 - Race Red - 19500mi. - Damage to rear and both sides of car, heavy damage on right side, no airbags deployed - up for auction in MS, June 2014
Boss #xxxx VIN 1ZVBP8CU0D5225994 - School Bus Yellow - 44230mi. - Passenger door caved in, A-pillar and floor bent, driver's airbag deployed - Nashville TN, Mar. 2015
Boss #xxxx VIN 1ZVBP8CU5D5226400 - Grabber Blue - 18300mi. FLOOD damaged car, water half way up the b-pillar, up for auction in OH, Aug 2015
Boss #0762 VIN 1ZVBP8CU2D5227021- Grabber Blue - 5600mi. - Damage to driver's side, fender, door and frame, rear quarter, driver's airbag deployed - Tuscon, AZ, Nov. 2013
Boss #xxxx VIN 1ZVBP8CU3D5228033 - GHIG - New Jersey-Hurricane Sandy Flood Car - Reported Dec 2012
Boss #xxxx VIN 1ZVBP8CU3D5228436 - GHIG - ??mi. - Heavy hit to driver's door, front of LR quarter, driver side airbag deployed, up for auction in FL, November 2013 - Purchased by Rehagen Racing, stripped to build a 302S replica.
Boss #xxxx VIN 1ZVBP8CU5D5231063 - Race Red - 21608mi. - Light front damage, LR quarter heavy damage, no airbags deployed, up for auction in NC, Nov 2017
Boss #1161 VIN 1ZVBP8CU4D5233080 - School Bus Yellow - Flood damaged in hurricane Sandy, roof crushed at windscreen - up for auction in NY, March 2013
Boss #1258 VIN 1ZVBP8CU4D5236075 - GHIG - 12350mi. - heavy damage to left rear quarter, secondary damage all over, up for auction in TX, Dec 2014 - PARTED OUT
Boss #xxxx VIN 1ZVBP8CUXD5237781 - Race Red - 467mi. - Flood damaged in hurricane Sandy - up for auction in NJ, January 2013
Boss #xxxx VIN 1ZVBP8CU6D5237857 - Grabber Blue - 1727mi. - Rollover, major roof damage - up for auction in Georgia January 2013
Boss #xxxx VIN 1ZVBP8CU3D5237878 - Grabber Blue - Rear ended - crushed right to back axle - up for auction in Georgia December 2012
Boss #1376 VIN 1ZVBP8CU1D5237894 - Performance White - 50500mi. - Front end damage to sheet metal and rad support, LR quarter, rear seats and carpet removed (for track duty?) - up for auction in NC, Mar 2015 - Partially repaired/repainted and up for auction again in NC, Jan. 2016 - LR quarter panel-beaten but not repaired.
Boss #1400 VIN 1ZVBP8CU5D5238028 - Grabber Blue - 21600mi. - Heavy damage to RF corner, both airbags deployed - up for auction in New Orleans, June 2014
Boss #xxxx VIN 1ZVBP8CU1D5238964 - Performance White - 17200mi. - Light front end damage to sheet metal and rad support - up for auction California Sept 2013
Boss #xxxx VIN 1ZVBP8CU3D5240389 - GHIG - Damage to right front corner, biologicals inside, both front airbags deployed - up for auction in Georgia - viewed July 2013 [UPDATE: Still up for auction in June 2015]
Boss #xxxx VIN 1ZVBP8CU3D5241297 - GHIG - 27000mi. - Damage to front left corner from T-bone impact, strut tower moved inboard, up to one airbag deployed - up for auction in Tex Dec 2014. Up for auction again in TX, Aug 2015.
Boss #xxxx VIN 1ZVBP8CU8D5242381 - GHIG - ??mi. - Texas hurricane flood damage - dash inoperable - no airbags deployed - up for auction in TX, Nov 2017
Boss #xxxx VIN 1ZVBP8CU2D5245602 - Race Red - Canadian car - Fire damage rear and passenger area - up for auction in Quebec, February 2013
Boss #1672 VIN 1ZVBP8CU8D5245622 - School Bus Yellow - Canadian car - Light front end damage, driver's airbag deployed, likely repairable - up for dealer sale in Quebec, March 2014
Boss #xxxx VIN 1ZVBP8CU0D5247042 - Performance White - 16157mi - light damage to front and rear fascias, roof and rear window, driver's airbag deployed - up for auction in SC, Aug 2013
Boss #xxxx VIN 1ZVBP8CU3D5247147 - Performance White - hit tree at driver's door. Heavy damage to door, side panel, floor, and A-pillar - up for auction in NC, Aug 2013
Boss #xxxx VIN 1ZVBP8CU9D5247878 - GHIG - ?? mi. - Heavy front damage along with RR quarter, 3/4 airbags deployed, had Vortek installed when crashed, up for auction in OK, Nov. 2013 - On eBay Dec. 2013 (not yet repaired)
Boss #1848 VIN 1ZVBP8CU9D5248786 - Race Red - 1100mi. - Damage to RF corner, strut mount moved inboard, driver's airbag deployed - up for auction in SC, Oct 2013
Boss #xxxx VIN 1ZVBP8CU5D5248879 - Performance White - unk. mi. - Damage to front end, LR quarter, front and rear suspension, all airbags deployed - up for auction in TN, June 2014
Boss #xxxx VIN 1ZVBP8CU8D5248956 - Performance White - 32750 mi. - Light damage to front end, bumper bar and forward frame rails shifted to driver's side, driver's airbag deployed, Likely repairable, up for auction in Amarillo TX, March 2015
Boss #2137 VIN 1ZVBP8CUXD5253222 - Grabber Blue - New Jersey-Hurricane Sandy Flood Car - Reported Dec 2012
Boss #xxxx VIN 1ZVBP8CU8D5255101 - Race Red - 13923mi. Damage to front bumper, rad support, frame rails, driver's airbag deployed, repairable, up for auction in TX, June 2015
Boss #xxxx VIN 1ZVBP8CU6D5260801 - Race Red - 570mi. Damage to front and rear fascias, LF wheel pulled forward, driver airbag deployed - Boston, MA - up for auction August 2013
Boss #xxxx VIN 1ZVBP8CU4D5261185 - Race Red - ??mi. - Damage to RF corner, all front end sheet metal moved leftward, driver's airbag deployed - up for auction in TN, Nov 2013
Boss #xxxx VIN 1ZVBP8CU6D5268445 - Performance White - ?? mi. - Damage to RF corner, RF shock tower shifted, drivers airbag deployed, up for auction in AZ, April. 2016
Boss #xxxx VIN 1ZVBP8CU9D5270657 - Performance White - ?? mi. - Rollover, damage to front, hood, roof - driver's airbag deployed - up for auction in LA April 2016
Boss #xxxx VIN 1ZVBP8CU1D5273505 - Race Red - fire with complete destruction of car - up for auction June 2013
Boss #2982 VIN 1ZVBP8CU0D5273768 - Race Red - 16370mi. - Damage to RF corner, all front end sheet metal moved leftward, three airbags deployed, up for auction in LA, Aug 2014
Boss #xxxx VIN 1ZVBP8CU1D5273942 - Grabber Blue - 9145mi. - Rollover, RF, LR corners and major roof damage - up for auction in Miami FL - Oct 2013
Boss #xxxx VIN 1ZVBP8CU2D5275067 - Race Red - ??mi. - Texas hurricane flood damage - dash inoperable - no airbags deployed - up for auction in TX, Nov 2017
Boss #xxxx VIN 1ZVBP8CU2D5277496 - Performance White - 15410mi - Damage to front end, rad support and frame rails, possibly repairable, driver's air bag deployed, up for auction in GA, May 2014
Boss #xxxx VIN 1ZVBP8CU4D5278133 - GHIG - 13000 mi. - Heavy damage to LF corner, strut tower pushed inward - up for auction in VA - Feb 2014
Boss #xxxx VIN 1ZVBP8CU6D5278182 - Race Red - 31700mi. - Damage to RF corner, suspension and fender, driver airbag deployed - up for auction in MD, April 2016
Boss #xxxx VIN 1ZVBP8CU8D5278359 - School Bus Yellow - 10370mi. - Heavy damage to front end sheetmetal, drivers airbag deployed, for sale in WI, Feb 2016
Boss #3347 VIN 1ZVBP8CU1D5278560 - School Bus Yellow - 5100mi. - Light front end sheetmetal and LR quarter panel damage, LR axle broken - no bags deployed - likely repairable - up for auction in NH, Jan. 2105
Boss #xxxx VIN 1ZVBP8CU4D5278777 - Grabber Blue - 4714 mi. - Rollover, damage to whole right side and roof - no bags deployed - up for auction in TX - Mar. 2014
Boss #xxxx VIN 1ZVBP8CU3D5279001 - Performance White - 35630mi - Texas hurricane flood damage - dash operable - no airbags deployed - up for auction in TX, Nov 2017
Boss #xxxx VIN 1ZVBP8CU9D5282825 - Race Red - 27940mi. - Rollover, damage to RF corner, hood, roof, no airbags deployed, up for auction in PA, May 2015
-- 2013 LS --
#LSxxx VIN 1ZVBP8CU3D5207716 - School Bus Yellow - 1500mi. - Light front end sheetmetal and RR quarter panel damage, possible front underbody damage - both driver's bags deployed - CA - April 2013
#LSxxx VIN 1ZVBP8CUXD5207809 - Black - 16211mi. - Rollover, heavy damage to roof and RR quarter, up for auction in Northern VA, August 2014
#LSxxx VIN 1ZVBP8CU2D5223843 - School Bus Yellow - 586mi. - RF sheetmetal and corner module damaged, oil pan punctured and front underbody scraped/damaged, no airbags deployed - Brookhaven, NY - listed July 2013
#LS210 VIN 1ZVBP8CU8D5233194 - School Bus Yellow - 1775mi. - centrifugal blower, damage to suspension F&R, driver's airbag deployed, up for auction in TX, April 2014
#LSxxx VIN 1ZVBP8CU5D5269361 - Black - Complete Burn - only ashes and steel left - up for auction in Dallas, TX - June 2013
With all this GREAT info provided by PT rocks. It seems like Yellow Blaze is the least wrecked color. I guess YB owners must be a better driver. 8)
Just saying.....The facts support this! ::)
Thank You Chris for all your hard work. I know this is not an easy task.
KUDOS to you!
2,009
441
Southeast
PTR:
This Boss 302 showed up at Auction in New York State with a Salvage title and Flood Damage was reported. Then some one in Germany made an inquiry about this Boss. It may have been exported to the EU.
1ZVBP8CUXC5271444 Boss Production #3151
EU Auction Link: Note the fuzzy picture?
https://www.easyexport.us/de/vehicle-finder/lot-29529314/2012-ford-mustang-flood-salvage-ny-rochester
Hope this helps the cause.
Dave
2HP
519
16
Is it just me, or is anyone else surprised at the number of cars that burned?
Does anyone know what caused the fires in any of the cases?
Seen a 2012 Boss Black LS this past Sunday. Last four digits of the serial #2163 I think. Got kicked off the property taking pictures. Hard hit LF. Air bags deployed. Site will not let put up pics for some reason?
Matt
byronj said:
http://www.autobidmaster.com/carfinder-online-auto-auctions/lot/32927025/COPART_2013_FORD_MUSTANG_BO_CERT_OF_TITLE-SALVAGE_VEHICLE_MADISON_WI/
It does have track key installed.
What the hell is the matter with these people in wrecking them.
519
16
VoodooBOSS said:
It looks like it rolled or did something roll over it? ;D
Almost certainly an animal strike. Could have been a moose, or an elk, or even just a large deer.
One of my neighbors hit a cow elk at only about 40 MPH with his Chevy Trailblazer. Totaled the Trailblazer, the elk was down for about five minutes, then got up and ran away. We saw it trailing the herd for a few weeks, then it was either well enough to mix in again, or a mountain lion got it.
