Master cylinder code - bleed system ?
Following up on ABS module thread from yesterday. So I used my scanner and read codes. It showed a master cylinder low/ pressure sensor. Sure enough it was low - I guess I had ran low on fluid when bleeding brakes and hadn’t noticed. Feel pretty dumb as I have bled brakes on this car a couple dozen times.
I filled to normal level but code won’t clear. Should I bleed master cylinder and then system?
