Re: Member Introductions
well...TYPICALLY sales or as a consultant OR go on to get your CCA (certified Crop Advisor) license. Now go figure the semester AFTER I graduate ISU offers a course geared toward getting your CCA and passing that nearly impossible test. As far as sales/consultant goes...in sales your typically looking at selling soybeans or corn are the 2 big ones in Illinois Iowa Indian etc...Personally I found selling seed difficult for me to justify as the major companies (I will not name any cuz I am employed by one) pretty well all use very similar genetics making it hard to "prove" your product is the better product UNLIKE cars. Sure there are some genetics that are under protection of a patent some genetics are found that when placed on a different carrier for the gene to be expressed the yield increases. not becaue the gene or overall makeup is "better" than the other just placed in a better spot on the plant that does't interfere with say pod development....if I get carried away I apologize its not often someone asks questions. on the consultation side is where I actually started. THAT was a side more easily argued. VRT or variable rate technology and/or application saves the farmer money. easy example. for corn nitrogen is a nutrient that is heavily depleted and usually needs to be applied every season in the form of anhydrous ammonia (NH3) aka the big white tanks you see if you live near rural america getting towed around by tractor and truck alike. anywho depending on soil composition and high/low areas in fields the overall depletion of NH3 or nitrogen in your field is different. at the price of anhydrous its cost effective to apply it where its needed instead of broadcasting it over all the field at the same rate say 100lbs/acre. INSTEAD soil testing and mapping can create what i call zones and zone A may only need 50lbs while B needs 150. in theory if you spread 100 over the whole field A has way more than it needs and B is lacking....I hope I didn't lose you especially since I kinda got excited and ran off on a rabbit trail.
four-walling said:You are welcome-now what do you do with an Agronomy degree?
