MT-82 strengths and weaknesses
Justin
Well I had clutch sticking to the floor wouldn't go in third. Tried all the band aid fixes. Nothing worked. Clutch line upgrade included(waste of money made it worse). Got centerforce dyad clutch problems went away. Now running a McLeod am still no problems shifting at all ever.
IMO the lockout issue is the flaw of the remote shifter design and a twin post mount and good motor mounts will cure this issue. The lack of centering springs in the shifter make it hard to find third so a shifter will improve this.
List of what didn't work for me in clutch sticking to the floor:
Clutch line JHR version
Dot 4 fluid
Removing the assist spring
Bbr motor mounts
What cured it:
Twin disc clutch from centerforce
McLeod is working great too
My opinion on spec clutches - they are junk. Those running them seem to still have issues and the puck design and harsh engagement are destroying third and fourth gear clusters
Had one in a previous mustang lasted two months.,,,
pufferfish
Supporting Vendor
1,094
66
Maryland
^THIS. the clutch pedal getting stuck to the floor is a separate issue from gear lockout.
I have the spec stage 1 and find it to be a great clutch. no engagement chatter, not too heavy on the pedal and doesn't have any neutral rattling like some of the twin discs. $600 for a clutch and aluminum flywheel is really hard to beat, as well. i just got pricing on a new oe boss flywheel and clutch and they are nearly the same price!
237
guys i have no experience on clutches ...
Can you guide me on how to choose which clutch ??
And When to change to an aftermarket slave cylinder ?
8,731
If you are looking for someone to rebuild and harden your MT82, there is a guy "Ben Calimer" on Facebook that does them. That's what I'm planning to do with mine if it takes a dump.
Clutch is a big part of mis-shifting stuff, plus mis-shifts may damage the transmission itself (synchros as Steve mentioned), so if you've jagged up the trans before going to an aftermarket clutch, you may still have some lingering shifting issues.
My car was vastly improved with the McLeod RXT.
Solid motor mounts made the shifts basically rock solid. The only issues I have are from my own poor timing now.
