NEW SHOES!...305 all around!
I'm in to hear your feedback about the 305s. Also, since I can't afford the BBS, I think these might be my track wheels. Maybe a Christmas present for myself? [checks bank book] :eek:
pufferfish
Continentals...are...AWESOME!
So much grip! And they actually give audible feedback at the limit! The 305's with this offset had no clearance problems whatsoever. I found that they like to be in the 36-38 psi hot range. To accomplish this, I started at 28 cold. It was a 72 degree day, so it might be completely different on a warmer day.
I will say I had a difficult time keeping wheel weights on. I don't know if it was necessary to put them near the rotors, but they were baking the adhesive off the aluminum tape. The weights placed by the back edge were just fine.
pufferfish
is that different than the aluminum foil tape used on HVAC? that is what I was using and have used for years, but nobdy has ever put the weights near the front of the inside hub (over the top of the rotor) and that is where the tape was baking off.
Probably similar. I know they use this stuff to "repair" passenger aircraft.
Also did someone say "305s"?
blacksheep-1
Epic Contributor
GOOD! you guys are "pickin' up what I'm throwing down" ;)
did you write down any more psi/ temps? and how long were the sessions?
Also Conti has always installed the weights on the wheels near the edge. We clean the wheel with lacquer thinner and use either "metal" tape or "grip" tape on the weights. As far as the wheels go, spray a little PAM on them and they'll clean right up after the race, but you have to MAKE SURE you clean the surface off when the tires get weighted or they won't stick.
Fomoco302
Life is short. Live well!
Somewhat off topic - just had new SVE Drift wheels installed on stock tires, only other change was went to 9.5 wide front vs. 9.0 stock. Above 60mph significant front end vibe. I'm guessing bad balancing ? Thoughts please.
pufferfish
Yeah, most likely balancing is off.
