New Wheels and Tires
Got my Forgestar F14 wheels and Michelin PSS tires finally mounted. The wheels are 19x9.5 +39 offset with 265/35r19 and 19x11 +53 offset with 295/35r19. Oce I get better pics I'll post up later.
I didn't get to weigh the new wheels and tires. I did measure the front stock wheels, 58lbs. I figure the rear would be about 60lbs. each. According to Tire Rack, the 265 is 25 lbs. I weighed each Forgestar and the front was 24 lbs. Combined the new set saves me approx 17lbs on the front. The rear wheels weighed 26 lbs and the tires 28lbs. This is a weight savings of 12lbs on the rear.
It may be in my head but the car does feel lighter, steering a little quicker.
Looking good! 8)
The performance benefits are real... :) Thanks for the posted weights.
Indeed, that is real benefit you will feel. Upgrading wheels is my favorite "bang for buck" upgrade as it makes everything feel my lively.
Where did you buy the wheels from?
DGRacing
Darren
Love it.
Okay that all sounds good and after research the forgestar looks like the way to go. I may just copy your set up thank you. I will be using these probably 90% for track time. I have other tires and wheels for the street. Are you using this set up at the track? It was either the forgestar or Apex. The other advantage to the weight is I have to lift them to put on the car and at my age any weight savings is great.
VoodooBoss
Rick
Your car looks fantastic. You'll like those tires compared to the stock Pirelli's.
