One piece driveshaft
JScheier said:
Could have been worse... mine were finger tight after Ford replaced my clutch ::)
Did you go to an adjustable UCA as well when you put in the DT shaft or are you still on the stock stuff?
JScheier
Too Hot for the Boss!
Still on stock stuff. My pinion angle / tail shaft angle are still within spec.
I will be adding the Goldtimatic UCA sometime in the next week or so... whenever I get time to slide myself under the rear of the car and wrestle with it.
Roger that. You are on 4150s, right? What kind of rear ride height are you running?
JScheier
4200RRs now. I'll have to check my rear ride-height. I used to have it memorized... too many rides on the Bacardi Bus have dented that section of my memory ;)
You know that is only funding Rum Bum Racing :-/
Too bad they make a fine product :)
Latest lap times
